News
360 experts I have a weird hazard (electrical) issue help please
Discussion in '360/430' started by LP360, Feb 14, 2021.
  1. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    484
    Eden Prairie, MN
    Matt
    I had a similar issue when i bought my 360, turn lights not working. Turned out to be pinched wire from when the bumper was reinstalled while work was done at the dealer.
    Qavion likes this.
  3. Qavion
    Qavion F1 Veteran
    5,190
    Ian Riddell
    Can you recall if both sides were not working, even using hazards?
  4. rotaryrocket7
    Dec 7, 2011
    484
    Eden Prairie, MN
    Matt
    Pretty sure it was both sides - memory (this is 5 years ago so a bit questionable) says that they are wired together, so if one goes the other does as well.
  5. Qavion
    Qavion F1 Veteran
    5,190
    Ian Riddell
    It would depend on your definition of "goes" and "wired together". A short circuit or open circuit on one side should only affect one side during turn indication operation (power is only sent to one side at a time). If the flash "relay" outputs were wired together, both sides would flash even during a turn. The turn indication on instrument panel is wired to both sides, but there must be diodes in the circuit to stop the sides interfering with each other.
  6. LP360
    LP360 Karting
    153
    Lee
    Update:
    All fixed! I was rushing around yesterday when I got the phone call about the issue so I'll try remember what they said lol..
    It was something to do with the permanent 12v wire, it was either fatigued or fraid. I'm sure they mentioned it was dropping voltage or had too much resistance when the hazards were activated and resulted in nothing working. My indy soldered in a new wire and all working 100%!
    Hope this helps anyone in the future if suffering similar issues and thanks to all who helped in this thread!
    I'll get a better understanding when I collect the car and report back
    Sent from my CLT-L09 using FerrariChat.com mobile app
    Qavion likes this.
  8. LP360
    LP360 Karting
    153
    Lee
  9. Qavion
    Qavion F1 Veteran
    5,190
    Ian Riddell
    Thanks, Lee!
    That was the only thing that really made sense to me.
    This seems to confirm that the module needs permanent battery (red wire) power (as well as key power) to operate the left/right turn signals. The hazards need only the red wire. Unfortunately, knowing this, it makes diagnosis harder for some faults.
    LP360 likes this.
  10. Qavion
    Qavion F1 Veteran
    5,190
    Ian Riddell
