360 f1 gearbox oil | FerrariChat
360 f1 gearbox oil
Discussion in '360/430' started by Majin_JT, May 7, 2017.
  1. Majin_JT
    Majin_JT Formula Junior
    Mar 15, 2008
    379
    JT
    #1 Majin_JT, May 7, 2017
    i have looked at a phew stories about which oil people use or prefer.
    But my question is will this oil pictured be ok for my 360 f1 ??
    thanks
    John_K_348 likes this.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    I have been researching gear oil for almost a month and almost concluded ..not done yet..so far after exhaustive research I came to is to buy ein /agip rotra lsx gear oil from eBay (Italy) or a local vendor but have to buy 12 quarts ...the next and last thing I am looking at is the motul 300ls
    Sent from my Moto G (4) using Tapatalk
  3. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    #3 Falcon Wing, May 7, 2017
    johnep likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    When I was doing my research I was looking for gl5 oil which is yellow metal safe and/ or had a gl-4 rating as well..and to top it off ...good for Limited slip
  5. RossoC360
    RossoC360 Formula Junior
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    #5 RossoC360, May 7, 2017
    I run Redline NS, just changed it out again last week, cleaned the filter and adjusted the cables, shifts excellent, my synchros and diff like it, and its GL5.
    whatheheck likes this.
  6. Rifledriver
    34,103
    Austin TX
    That is GL4. Ferrari for better or worse calls for GL5.
  7. Rifledriver
    34,103
    Austin TX
    There really isn't a brass safe GL5. It becomes a matter of degree. Ferraris modern transaxles call for GL5 because of the differential but GL5 additive packages are contrary to the needs of synchronizer operation and to varying degrees are harmful to brass.
    Some feel GL4 is a better choice but it does not meet the GL5 spec Ferrari calls for.
  8. tazandjan
    38,077
    #8 tazandjan, May 7, 2017
    I use Valvoline Synpower Full Synthetic Gear Oil with Anti-Slip in 75W-90. No issues with chattering limited slip.
    Just about any full synthetic 75W-90 transmission/gear oil will work. As noted, many owners use Redline 75W-90 NS, but that sometimes requires adding a small amount (very small amount) of anti-slip additive.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    #9 flash32, May 7, 2017
    I choose the rotra lsx because it seemed to be the best ...gl-4 and gl-5 and ls ...it also mentioned it can be used in regular gearboxes which also leads me to believe it should be good for syncho ..I also have a call out to the motul tech line to understand their ester based formula which supposed to be gl5 and yellow metal safe as well
    I called Mobil 1( for their syn ) and Valvoline ( for their synpower) and did not get a warm and fuzzy about yellow metal safe ...first they said yes then they say no ...and both do not recommend in regular gearboxes
  10. Rifledriver
    34,103
    Austin TX
    The oil companies are all calling GL5 safe for brass but only because they have reduced the damage to what they consider tolerable. I have boxes full of destroyed Ferrari syncros lubricated by their tolerable blends. In any event GL5 by its very nature inhibits syncro action. It protects hypoid gears in a manner that delays syncro action.
    I have every confidence they will all tell you it will be just fine.
  11. RossoC360
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    Heres the results of copper strip tests for a number of gear oils if anyone is interested, Enjoy!
    M/T FLUID & GEAR OIL WEIGHT API CLASSIFICATION
    Amsoil Long Life FGR 75W-90 GL5 1B Dark Orange
    Amsoil Severe Gr SVG 75W-90 GL5 1B Dark Orange
    Amsoil M/T Fluid MTF 5W-30 1A Light Orange
    Amsoil MT & Gear MTG 75W-90 GL4 1B Dark Orange
    Castrol Hypoy C 80W-90 GL5 1B Dark Orange
    Castrol SYNTEC 75W-90 GL5 1B Dark Orange
    Citgo Citgear Std XD 75W-90 GL4 1B Dark Orange
    Delo Gear Lubric ESI 80W-90 GL5 2A Claret Red
    Delo Trans Fluid ESI 50W 2A Claret Red
    GM Synthetic Axle 75W-90 GL5 1B Dark Orange
    Lucas 75/90 Synthetic 75W-90 GL5 4B Graphite Blk
    Mobil 1 Synthetic 75W-90 GL5 1B Dark Orange
    Mopar Synthetic
    w/Mopar LS additive 75W-90 GL5 4A Trans Black
    Pennzoil Gearplus 80W-90 GL5 1B Dark Orange
    Pennzoil Synthetic 75W-90 GL5 1B Dark Orange
    Red Line MT-90 75W-90 GL4 1A Light Orange
    Red Line NS Gear Oil 75W-90 GL5 1B Dark Orange
    Red Line 75W90 GL-5 75W-90 GL5 1B Dark Orange
    Royal Purple Max-Gear 75W-90 GL5 4A Trans Black
    Torco SGO Synthetic
    w/Torco Type G LS add 75W-90 GL5 1B Dark Orange
    Valvoline High Perf 80W-90 GL5 1B Dark Orange
    Valvoline SynPower 75W-90 GL5 1B Dark Orange
    The classification scale ranges from 1A (least corrosive) to 4C (most corrosive).
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    #12 flash32, May 7, 2017
    Here is the spec on LSX
  13. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,366
    I use 75/90 with additive
  14. Rifledriver
    34,103
    Austin TX
    That in no way is why brass syncros are damaged by GL5. It is not a corrosion issue. The oil companies know it and the test only provides a false sense of security.
  15. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    Seems that GL4 is bad for the diff and GL5 is bad for the syncros.
    Which do you use/recommend?
  16. tazandjan
    38,077
    Could be worse. Seems like early Miuras shared engine and gearbox oil, a real mismatch.
  17. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    Yes that would be worse. But I'm only now sleeping after having jettisoned my pre cats. Now I'm lying awake at night listening to my syncros being munched!
    Prit Singh likes this.
  18. RossoC360
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    I did not intend to imply that it was, just thought it was interesting read. What your seeing with synchro wear would most likely be a result of the coefficient of friction between the additives is the oil and the brass. BTW thanks for you input on the forum!
  19. Rifledriver
    34,103
    Austin TX
    No it has been talked to death here though and I am not a big fan of repeating the same information over and over. There is a great deal in the public domain and the list of transmission suppliers that do not use GL5 and specify it only in differentials is a long and interesting list. Most companies refer to GL5 as differential oil and GL4 as transmission oil for good reason.
  20. Rifledriver
    34,103
    Austin TX
    Not completely true. GL4 was quite happily used in differentials for a very long time and GL5 was developed for specific reasons, not because GL4 was not useful for that. I am not advocating the use of GL4 where Ferrari (almost singularly) calls for GL5. I just believe that people that make that choice should be fully informed about the intended use and side effects before doing so.
  21. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,368
    I almost got my head round this, but now just confused again.
    So, are we saying....
    RL MT-90 good for syncros not so good for LSD
    RL 75W90 not good for syncros, but good for LSD
  22. Rifledriver
    34,103
    Austin TX
    No, wrong on both counts. I don't recall mentioning lsd at all and it really has nothing to do with any of this.
  23. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    Post #20 from Rifledriver sums up his take on GL4 and GL5 oils, regards to transmission and differentials.
    ....now he has me thinking to GL4 instead of GL5. Now I'm confused. LOL :)
  24. Majin_JT
    Mar 15, 2008
    379
    JT
    #24 Majin_JT, May 9, 2017
  25. Rifledriver
    34,103
    Austin TX
    How does that become a "Safe" choice?
