News
360 360 F1 troubles!
Discussion in '360/430' started by jg360, May 11, 2019.
  1. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    I have been working on my F1 system for a year and have been chipping away at a bunch of issues. So I’m getting an inconsistent grinding when shifting up or down. It doesn’t grunt in the same gear every time. If I back off the throttle and shift then no grinding. It’s basically under a heavy load. It doesn’t grind at full tilt either. I’m at the point of just pulling the trans and replacing everything in there. Before I do this. This is my last attempt to figure out this last issue. I’m posting the latest printout of all the values for you guys. Maybe someone can let me know if they notice anything out of spec.
    Basically have replaced the pump, accumulator and actuator. Bleed the system several times. Replaced the oil and trans oil as well. Did the centering and relearn process over and over.
    Pressure looks good. Played around with the pis but no change. I was told the delta centering value looks high but I’ve tried to recenter and keep getting the same value.
    Any help would be appreciated. Thanks. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
  3. radlu
    radlu Formula Junior
    Jun 6, 2005
    335
    You're on the right path.
    Yeah, I would replace everything in the Transmission. Geers, Shafts, Bearings, Diff. Sickros, Etc
  4. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    Might as well replace the car....
  5. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
  6. becir1
    becir1 Rookie
    Oct 9, 2008
    16
    Germany
    #7 becir1, May 11, 2019
    Hi jg360
    The Clutch Wear Index value is too low.
    The Clutch Wear Index value should be between 3000 and 4000. I would set the PIS Point from 4.97 to 5.1, and do a self-learning test and drive the car for 1 hour or more. To turn more often the gears. Then read the clutch wear index again with the diagnosis. Now the value should have gone up.
    Which diagnosis version do you have?
    With X-Diag PRO3 you can also use decimal numbers with version 10.80. Incidentally, the PIS value at CFC 201 SoFast 1 are
    Min. 4.8 / Base 5.1 / Max 5.4
    The clutch wear index learns during the ride and during the gear change, the longer you drive the more the system learns.
    After setting the PIS point, the circuit will not switch so well, but that will change during the ride it is getting better.
    brookliner7 likes this.
  7. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    becir1, I am currently using the EZdiag. I am able to change the pis with a decimal but is a little tricky since it spits out a different number than what is entered. I did have it set above 5 and the car was shifting very lazy! I’ll try it again and see what the wear index value comes back at.
  8. 24000rpm
    24000rpm F1 Rookie
    leonardo does the same with a different number(close)
    so no worries unless you entered 4.5 and it comes up with 4.7
  9. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    I’m just getting worried about the grinding. It seems as if the clutch is not being engaged enough to have a smooth shift. Almost like a 6speed when depressing the clutch pedal halfway and trying to shift and it would grind.
  10. mello
    mello F1 Rookie
    3,112
    CA Bay Area
    Steve
    Sounds like the clutch is intermittently disengaging. Pressure plate and/or throw out bearing is about to go south would be my guess. Any visible trans-axle oil leak? You've tried everything that I would do. A mechanical issue will not be solved by fiddling with any type of TCU parameter adjustments. I would start doing a tear down at this point.
  11. eric355
    eric355 Formula Junior
    877
    Toulouse (France)
    Eric DECOUX
    My guess also.
    With a new clutch position value at 14.59 mm and a current closed clutch position at 19.88mm, your clutch wear is about 90% ! I would seriously think at looking at it ...
  12. RedNeck
    RedNeck F1 Rookie
    4,643
    TN/GA
    Matt
    No help here as I'm gated, but that was the same fella that told another member to just replace a quarter panel and go after a bad engine bay fire. I thought he was joking....he wasn't.
  13. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    So I thought that by subtracting the two and dividing by 8.5 you get the clutch wear. I thought I was around 60%
  14. UrbanHero
    UrbanHero Rookie
    Apr 18, 2019
    17
    New York Pothole City
    Marlon
    Does EZdiag allow you to bleed the system after you changed the Actuator? My actuator just developed a small leak and I'm contemplating if I should remove and take a look at it and see if I can repair it since I'm very hands on.... 2000 360 f1.
  15. brookliner7
    brookliner7 Formula Junior
    May 5, 2018
    336
    San Antonio, TX
    Hans
    When is the last time the entire clutch was changed with the throwout bearing? How many miles are on the car?
  16. UrbanHero
    UrbanHero Rookie
    Apr 18, 2019
    17
    Marlon
    28691k currently on the clock, clutch was changed at 24k.... 30k service was performed in January at 28500k.
    Sent from my SM-G955U using FerrariChat.com mobile app
  17. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    40k. Not sure when the last clutch change was. No service records.
  18. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    I figured that the clutch would be slipping if it were getting close to its last leg
  19. UrbanHero
    UrbanHero Rookie
    Apr 18, 2019
    17
    Marlon
    I was wondering does the Ezdiag allow you to do functions like bleeding out the f1 system
  20. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
  21. viperguy
    viperguy Rookie
    Feb 4, 2004
    21
    Hello, could you share more about the ezdiag scanner tool. What tool you used to go with the ezdiag software? I am having F1 problems on my 01 360 and I need a scanner, my autel 908 pro does not work. What year is your car? I appreciate any help. Thanks
  22. UrbanHero
    UrbanHero Rookie
    Apr 18, 2019
    17
    Marlon
    https://m.obd2tool.com/goods-5052-Launch+X431+iCarScan+Bluetooth+Diagnostic+Scanner+for+Android.html
    That's the tool to use, and it works for all years of the 360!! It ships from China....
    tifosi101 likes this.
  23. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
    So looks like I was able to get the delta actuator venting down from -73 to -48 and improved the shifting and most of the grinding went away. I figured to try and and get it lower but ended up going back up to -79. I need some help on the proper procedure. I was just trying different thing and not sure what I did to get it to lower. Any help would be appreciated! Thanks.
  24. jg360
    jg360 Karting
    Feb 8, 2018
    177
    New Jersey
    John Gurrieri
