360 Fuel Smell | FerrariChat
360 Fuel Smell
Discussion in 'Technical Q&A' started by rkdav, Mar 1, 2009.
  1. rkdav
    rkdav Rookie
    Sep 7, 2007
    24
    Beaufort, SC
    I experienced this for the first time on a drive yesterday with the top down on my 360 Spider. A whiff of raw fuel but only twice and only very fleetingly. There is no sustained fuel smell whatsoever either in the cockpit or in the engine bay, nor can I see any evidence of a leak. Obviously I don't expect you guys to diagnose this from afar but was wondering if anyone had had a similar experience and, if so, what was the cause. The fuel tank is about 2/3--3/4 full. Thanks.
  2. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Plastic vent fittings on the top of the fuel tanks crack. You should have a CEL on...... that was on to alert you to the problem, don't ignore it. Those headers are quite close to the common leakage source
  3. rkdav
    rkdav Rookie
    Sep 7, 2007
    24
    Beaufort, SC
    Thanks. No CEL light is on, though. I'll keep an eye on it. I spent a lot of time with the car yesterday detailing the engine compartment, etc. Nothing loose was noted. I did notice the gas cap wasn't as tight as it is normally and that there was a little fuel smell coming from there. I tightened it and will have to see how it does on the next drive. Weather was lousy here yesterday so the car stayed in the garage.
  4. Stew
    Stew Formula Junior
    Apr 16, 2006
    547
    Los Angeles
    In the compartment that houses the convertible top there are two access panels. You can access the top plastic rings above the fuel tanks/fuel pump. My Ferrari tech had a big sort of "wrench" to CAREFULLY tighten the rings. He also had a chemical "Smoke" generation machine. He hooked it up to the gas cap. It pressurized the entire fuel system. You can SEE any leaks in the fuel/vapor recovery system. I highly reccommend this proceedure. In the proper hands, it is a very helpful diagnostic tool.
    Regards,
    Stew
  5. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,075
    PDX
    Kevin M.
    FWIW, double check your fuel cap. Kind of easy to cross thread and lead one to believe that it's secured when really it's not.
    I only say this because the pump monkeys that we are forced to use here in the great state of Oregon tend to mess this up each and every time. I also have to go back and check their work.
    If you aren't complete screwed down tight, you will get some fuel smell (and sometimes a CEL).
  6. f355spider
    f355spider F1 World Champ
    17,940
    There are a couple threads on this, with pictures. It is serious enough that you should probably have it inspected by a qualified shop. Gas vapors are not something to mess with.
  7. BoulderFCar
    BoulderFCar F1 World Champ
    12,193
    Asheville, NC/Ft Lauderdale
    Tom
    #7 BoulderFCar, Mar 3, 2009
    Having seen what can happen with this the above quote is classic understatement in Dave Helms speak. I hope it's just the gas cap but get it checked.
  8. rkdav
    rkdav Rookie
    Sep 7, 2007
    24
    Beaufort, SC
    Thanks, guys. The gas cap was loose, so much so that I could smell fuel around it. Why the CEL didn't illuminate, I don't know. Maybe the cap wasn't quite loose enough to do that. Anyway, it's tight now, I've inspected as best I can and found no leaks and the next step is the drive to see if the smell recurs. If so, it's straight to the shop. I appreciate the input from you all.
    Thanks again,
    Rick
  9. patpong
    patpong Formula 3
    Jul 6, 2004
    2,274
    Bangkok, Thailand
    Patpong Thanavisuth
    get the car checked... all fuel related hoses, cap, lid... there were two 360cs caught fire the last month, one here in Thailand and the other in Hong Kong... The one in Thailand, driver mentioned fuel smell... both burn to the ground... since then, everytime I get into my fast car, I bring along fire extinguisher...
    http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=1114314120
  10. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    on my coupe (not spider), I noticed a gas smell once back in the engine compartment while working on some stuff. I removed the panel on the right and noticed the little vent hose for the gas tank was routed a little bit funny. I changed the routing and the smell went away. Not sure how they do it on the spider, but it could be related.
    Ray
