360 gearbox cooler delete? | FerrariChat
Discussion in 'Technical Q&A' started by DDavid, May 31, 2018.
  1. DDavid
    DDavid Karting
    May 3, 2018
    57
    DDD
    My heat exchanger died on my 360 6 speed Spider and filled the gearbox with coolant. It’s been suggested to me that perhaps I should delete the cooler altogether. Other suggestion is to replace it with an air to oil cooler like on an automatic transmission. I’m concerned that might over cool the oil which I fear will make the shift notchey and tight. I’m chasing thoughts on this asap.
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    This style of heat exchanger also serves as a warmer for the gearbox fluid, cleanup is a PIA, but why change from stock? It works.
  3. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,132
    PR, TX, GV
    Jaime
    I concur.
  4. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Yeah, you don't need that. Just delete it.
  5. Mel Spillman
    Mel Spillman Formula Junior
    715
    Sugar Land, Tx
    Mine is deleted and everything is fine.
  6. DDavid
    DDavid Karting
    May 3, 2018
    57
    DDD
    Thank you very much. I’m going to delete it. Relative to the use it will receive, I’m confident it’s not a huge loss.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
  9. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,931
    The Cold North
    Tom
    I have had requests to delete them, and have done so. I install new lines modified to work with an external cooler which I mount in the opening behined the rear wheel. The wheel well cover needs to be cut open to allow the air flow and a screen installed. Mounting brackets need to be made up for the cooler, the lines modified to fit the cooler..etc.
    That said..its cheaper to replace the stock unit.
    ///Mike likes this.
  10. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    who makes this upgraded version?
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Alex at Daytona auto in Ontario Canada.
    ExcelsiorZ likes this.
  12. RedNeck
    RedNeck F1 World Champ
    12,209
    The CSA
    Me
    Just changed mine, as PM sinceI had the intake off. Original lasted for 55k, with proper maintenance, my new one should last past 100k. under $500 to replace. No need to get cute.
    Halitos likes this.
  13. DDavid
    DDavid Karting
    May 3, 2018
    57
    DDD
    I’m told on a Spider that the entire roof assembly has to come off in order to replace it.
  14. tbakowsky
    Sep 18, 2002
    19,931
    The Cold North
    Tom
    You have been told a lie. Intake does not need to be removed either..
    2NA likes this.
  15. DDavid
    DDavid Karting
    May 3, 2018
    57
    DDD
    That’s very interesting. I’m told beyond any doubt that the roof AND the intake has to come off. Im not doubting you, but can others please chime in to confirm this?
  16. Toonfosi
    Toonfosi Karting
    209
    Valley Village, CA
    Chad Woods
    Here’s a pic from my spider moments before I pulled the exchanger. Just go through the belt access cover and pull the water pump first.
    2NA likes this.
  17. Mel Spillman
    715
    Sugar Land, Tx
    Roof does not have to come off. I have seen a heat exchanger replacement and a bypass done without removing the water pump or the intake!!
  18. mello
    mello F1 Veteran
    5,482
    CA Bay Area
    Steve
    How is the bypass done? What components are used? Just curious.
  19. hessank
    hessank Formula 3
    1,911
    Canada, Florida
    Fred
    Mine was replaced with the upgraded one from Daytona (made with a different material) and the roof did not have to be taken off.
    Now that I am personally taking care of the cooling system (changing the fluid every 2 years) I will no longer worry about this item failing (fingers crossed)
    However, at any hint of degradation of this HX I will eliminate it.
    TV5R likes this.
  20. Mel Spillman
    715
    Sugar Land, Tx
    The only materials used was a good quality coolant hose. He just took his time and got the clamps off, slid the heat exchanger out and replaced it with the hose and new clamps. It was magic to watch!!!
  21. ExcelsiorZ
    ExcelsiorZ Formula 3
    1,267
    Beverly Hills
    Can folks who have deleted the cooler altogether share their post-install feedback?
    I am thinking (1) this is a heater more than a cooler as the gear oil takes longer to warm up than does the water and perhaps Ferrari was addressing its notorious difficulty of shifting into second gear until the gearbox was warmed up?
    (2) is this really a cooler that is needed? Does the gearbox in the F355 really run that hot that it needs an external cooler?
    For those who have bypassed, any cold shifting issues? Any overheating gearbox issues?
  22. modificator
    modificator Formula Junior
    434
    Florida
    George
    Without personal experience (which I will soon have, as I've got a leak too) I'm guessing that "it depends" and Ferrari has done it for a reason, to address various conditions.
    So for someone racing and overheating gearbox, or driving in a polar bear country and needing gearbox warmed up - a new heat exchanger is needed.
    With reasonable street driving in a climate like Florida I think we can live without it. Unless originality is important.
    Mel Spillman likes this.
  23. tbakowsky
    Sep 18, 2002
    19,931
    The Cold North
    Tom
    You can live without it. Do the loop bypass and you will be just fine. As stated it is not really a cooler..it's more of a heater then anything. If you are really concerned, you could add a remote cooler rather easily.
  24. Mel Spillman
    715
    Sugar Land, Tx
    Anthony 360 F1 and hessank like this.
  25. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,441
    On the Limit
    Dino
    Mine failed and I replaced it with an OEM unit. It was an absolute PIA. However, Ferrari did the R&D and put one in for a reason. The Challenge cars have a cooler that is external to the V, which is nice.
