360 MAF (Mass Air Flow) Sensor Price | Page 7 | FerrariChat
Discussion in '360/430' started by Akram, Aug 24, 2010.
  1. MikeR397
    MikeR397 Formula 3
    May 9, 2010
    1,469
    SE Michigan
    See earlier in the thread. They used to be priced lower it looks like and had a make an offer button. I think i offered $150 and they countered at $160usd each is what i paid.
    They were shipped directly to my shop. My mechanic said they looked oem, came in bosch box, but i did not ask about any seals or serial number matching.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    Just for reference this part number isn't correct for the AFM used on the CS. Its actually the same pn as a F430 and 599 which is Bosch Pn#: 0280218085;
  3. Rnye
    Rnye Karting
    Mar 17, 2014
    177
    Las Vegas, NV
    Thanks for the heads up guys! Ordered two and they've already shipped for less than 1 through Ricambi. Maybe we should stock up? LOL
  4. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    what differences will it make to use 430 MAF?
  5. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
  6. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    It's larger and won't fit the air box pipe...
  7. 24000rpm
    24000rpm F1 Rookie
    #157 24000rpm, Feb 5, 2016
  8. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    I'm curious, what are you actually trying to accomplish by doing this ?
  9. stevecomp
    stevecomp Formula Junior
    Mar 1, 2013
    743
    South Australia
    Steve
    #159 stevecomp, Feb 5, 2016
    The 430/360CS unit would be great for a low boost turbo application without throwing a code as it allows for more air flow :)
  10. 24000rpm
    24000rpm F1 Rookie
    Because one of the Modena's MAF went bad(engine throw a code), so I swap over another one to confirm. I wonder if the CS insert & modena insert are 100% interchangeable without performance change. I personally can't feel anything after the swap
  11. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    I'd love to get other people's opinions on this...
    I was actually thinking it would do the opposite, i.e. result in a rich mixture thus the o2 sensors having to kick in to tell the ecu to lean out the mixture further.
    Since the CS/F430/599 AFM has a slightly wider diameter vs the 360 AFM, so putting the CS sensor in the smaller diameter housing of the 360 AFM (if thats what's been done) would trick the sensor into putting out a signal that would indicate to the Bosch ECU that more air was passing through the AFM than really is the case, i.e. richer mixture !?
    If I thinking about this correctly and he'd done it the other way around, i.e, fitted the 360 sensor in a CS/F430/599 AFM housing it would result in more air passing by the sensor for the given outputted signal thus leaning out the mixture way more than it should be and potentially leading to melted pistons if too much air got in for the given amount of mixture!
    People be careful doing these kinds of experiments unless you have a wideband lamba sensor and a dyno to test it out on (or a spare engine).
  12. stevecomp
    Mar 1, 2013
    743
    South Australia
    Steve
    (BOSCH NO.0280218058) also cross references to VW Passat.
  13. stevecomp
    Mar 1, 2013
    743
    South Australia
    Steve
    #163 stevecomp, Feb 5, 2016
    Use the 430 AFM body or it will have issues, the larger size allows more air to pass without throwing a code. Been boosting for a long time, wideband 02 sniffer and two piggy-back fuel controllers (Power Commanders PC3's) controlled from a 2BAR MAP, 10PSI = 100% TPS and map from that scale add or remove fuel were needed for easy and effective mappable boost control. You can also do this with a N/A motor to map fuel via the TPS without access to the ECU's I've done this many times when I could not map the ECU directly, it works and it's very simple.
    Pictures show one for each bank, they fit between the injectors and the loom, the grey wire is a 5 Volt signal wire can go to TPS switch or MAP for boost.
    Use a LM2 for AFR and you can map the piggy-back fuel controllers were needed. Plus you don't need a dyno the road is your dyno with a data logger.
    LM-2 Wideband O2 Digital Air/fuel Ratio Meter
  14. 24000rpm
    24000rpm F1 Rookie
    wow, I see, so that does mean I better not to put a CS insert into a Modena then.
