News
360 Modena air conditioning?
Discussion in 'Ferrari Discussion (not model specific)' started by Chrissy p, Jun 24, 2019.
  1. Chrissy p
    Chrissy p Rookie
    Jun 19, 2019
    6
    Leicestershire UK
    Chris peat
    Just still getting used to my first Ferrari
    Does anyone know if I’ve got air con & how do you turn it on?
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    11,062
    South East
    Jimmie
    #2 greyboxer, Jun 24, 2019
    This is going to sound weird but its not air conditioning but climate control (so depending on temperature it uses a/c to cool car or heat to warm car) - read the owners manual and then experiment with what you think is the a/c on/off button but is actually climate on/off as well as the other buttons
    There are many extended threads about this in the 360 section eg https://www.ferrarichat.com/forum/threads/what-does-the-stop-button-do.443501/#post-143045193
    And to add to the confusion for many years the manual said off when it meant on !
  4. bernieb
    bernieb Karting
    Apr 16, 2007
    74
    Alberta Canada
    Bernard J Bonertz
    You were able to start it?
  5. RedTaxi
    RedTaxi Formula 3
    1,813
    New Zealand
    Glen
    Default is on. You press the button in to turn it off.
    Caphill likes this.
  6. Dino6304
    Dino6304 Karting
    104
    CT
    Laurence
    If the STOP button is pushed in and lit, I am assuming the a/c system is off.
    Correct?
    I have a 2002 Modena
  8. G. Pepper
    G. Pepper Two Time F1 World Champ
    21,843
    Texas/Colorado
    George Pepper
    Yes, you have to use STOP to turn it off. Default is ON. Just set the temp you want and the system chooses heat or AC depending on what is needed.
  9. Dino6304
    Dino6304 Karting
    104
    CT
    Laurence
    Thanks very much
  10. Zanny1
    Zanny1 Formula Junior
    623
    Fountain Hills, Arizona
    Jeeeez.....STOP button turns off the climate control. Your AC and Heat will not function with the STOP button pushed in.
    Not sure why it was designed that way.... a guy I know that used to track 360's said he disengages the climate control any time he runs the motor to redline. Make sense to me.
    EastMemphis likes this.
  11. Dino6304
    Dino6304 Karting
    104
    CT
    Laurence
    With the system button stopped, fresh air only?
  13. Zanny1
    623
