Hi everyone Just had a set of AFCO shocks fitted to my 360 Modena and am very pleased with the result. The handling more positive and the car is firmer though still fine for autoroutes in France where I am based. One thing that concerns me is that I now have an error on the dash showing a suspension fault. I guess this us because the electronic dampers are not connected. Does any know if this error can be removed? I hope I'm correct in assuming this us not a problem but I would like it removed if possible. Can someone help with a constructive solution. Many thanks.
Interesting modification @zipperkarting ! AFCO shocks set have a specific reference for 360 Modena ? Anyone (@360trev ?) here knows how to simply delete the suspension warning on the dashboard when the connectors are free ? Maybe by connecting an electrical resistance to each shock connector ? But how many Ohms ? Image Unavailable, Please Login Otherwise there is the KW solution : module ref. 66042001 Image Unavailable, Please Login Image Unavailable, Please Login
That is an odd issue. I did that 12 years ago and never had a suspension issue resulting in a light. Make sure the sensor for the ABS is seated properly
