360 - 360 shift gate | Page 2 | FerrariChat
360 360 shift gate
Discussion in '360/430' started by jg360, Mar 3, 2019.
  1. jg360
    jg360 Formula Junior
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
  2. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    Phemes. Three more measurements please.
    Reverse slot width and the finger between reverse and 2nd
    Need the neutral position and width. Maybe the top of reverse can work
  3. Phemes
    Phemes Rookie
    Jul 16, 2012
    34
    Bonner Springs, Kansas
    Phil Hemes
    Unless I am misunderstanding your question you should already have all those dimensions. All finger widths are the same @ 5.7mm. Slots are all equal also @ 10mm. Neutral position width is total width of all slots @ 59.6mm and centered front to back.
  4. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    Ok. I was looking at few photos and the finger between r and 2 looked a little larger than the rest.
    So if I add up all slots and fingers it totals 57.1. Am I missing something
  5. Phemes
    Phemes Rookie
    Jul 16, 2012
    34
    Phil Hemes
    Gotcha, all to do with draft angle. OK, I would make the finger between reverse and second 6.7 mm and the reverse slot 11.5mm, that will eat the error.
  6. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
  7. Phemes
    Phemes Rookie
    Jul 16, 2012
    34
    Phil Hemes
    On the top face yes, they are all slightly different due to gear lever angle. They may all be the same on the lower face.
  8. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
  9. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    I don’t think you understand. They are all the same width top and bottom. BUT the top hole and bottom hole are offset because of the draft angle. You are modeling it as a slot perpendicular to the plane and that is the source of your error.
  10. Shinigami
    Shinigami Formula Junior
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
    Mikael-F360 likes this.
  11. Shinigami
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
  12. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    Yes, I do understand. I am just getting the basic shape down first. I’ll work on draft angle and top curve next.
  13. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    Is the bottom truly flat?
    If the bottom is truly flat as shown and you project a straight slot from the bottom to the top with a draft angle, it will create a curved slot on top.
  14. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
  15. Phemes
    Phemes Rookie
    Jul 16, 2012
    34
    Phil Hemes
    I don't think you really mean "hole" do you?
  16. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    Are you really nitpicking the word hole vs slot? Notice that holes do not have to be round. Or are you saying that I more correctly should have said 'the outline caused by the intersection of the hole and the top surface will be offset from the intersection of the hole and the bottom surface'. Either way it looks like you are intentionally being obtuse.
    Let's face it, the shape of the cutout on the top surface is different than the one on the bottom surface. That makes your 'roughing it out' wrong and difficult to fix.
  17. Phemes
    Phemes Rookie
    Jul 16, 2012
    34
    Phil Hemes
    Errrr, you have a serious problem !
  18. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Best way to look at this properly is to 3D scan the original part and go from there..
  19. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    That would be great if someone has a 3D scanner and an original gate.....;)
  20. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,428
    Honolulu
    Kevin
    Boy you guys are getting feisty. It is very close now and almost ready to machine. Looking good!
    How will you approach the cavallino rampante ?
  21. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    So I’ll have the shift pattern etched on since the option with the carbon knob came with the Cavallino on it.
  22. 24000rpm
    24000rpm F1 Rookie
    is the oem unit cast from a mold?
  23. Threesixty365
    Threesixty365 Rookie
    Nov 21, 2018
    5
    JASON KITCHEN
    Send me the file and I'll 3d print it on a half-million dollar machine. It's will be right to a few thousands. I'll do it for free for fun. Also if someone had a real gate I could model it flawlessly, scanning doesn't work the way you think it does and wouldn't help any, traditional measuring is the only way to get it perfect to less than .001. Factory is cast then finish machined like most Ferrari parts, I want to machine one out of ptfe impregnated brass, those would be some nice shifts.
  24. Europeanroadandracing
    Europeanroadandracing South Carolina
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
  25. Europeanroadandracing
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
