360 shifter bushing repair | Page 5 | FerrariChat
Discussion in '360/430' started by chrmer3, Jul 11, 2009.
  1. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    Apparently, you don't have to disconnect the cables and remove the shift rod.
    http://youtu.be/qxrLnNDiICU
    I don't completely understand the part where the punch and funny pliers are used in disassembly.
  2. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,349
    Honolulu
    Kevin
    I don't recall looking at it and thinking there was some shortcut but you might figure something out. If you are referring to my pictures the forceps are just there to stop the assembly from moving down as I pop the retaining cups off the end of the shifter. You could use anything metal if it was strong/thin enough. I have the pliers reversed because I am using the plasti-dipped end of them to protect the parts I am prying on.
  3. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    I was referring to the video link. They replace the bushing without removing the cable or the shaft.
  4. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    I have had the worst luck replacing the small block, part #172934. I'm using a shim to the left of the block and hammering lightly on the rod. If I tap lightly, the ball does not go in, but when I give it some force, it breaks right off. I've spent almost $100 on a $30 part that looks like it's worth 50 cents!
    Does Hill offer this in aluminum? They should.
    I greased the inside of the block and the end of the ball pin. I'm wondering if that's actually producing greater resistance instead of helping it to slide in place. Any tips would be appreciated.
  5. vrsurgeon
    vrsurgeon F1 World Champ
    16,445
    Charleston, SC
    Curt
    What I did when I replaced it.. yes it is "fun" to put back in.
    I didn't take the entire assembly out of the car btw. What I did was I put a metal plate in between the shift rod and the socket piece it goes into and then put gentle force to get it to pop onto the shift lever. Then I took the plate away and fit it into the socket assembly.
    Just be careful with the moving parts of the assembly, like the socket part it fits into. I made the mistake of pressing downward when I should have pressed sideways and *POP* I broke it. $150 later it was fixed. But it's brittle material and silly mistakes add up.. BTDT!
  6. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    Thanks Curt. Did you press it in by hand then? Did you go at it straight on? Did you lube around the block or the round end of the pin or leave it dry?
  7. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    diagram possibly?
  8. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    what grease should be used when relubing these parts?
  9. vrsurgeon
    16,445
    Charleston, SC
    Curt
    #109 vrsurgeon, Jul 8, 2015
    I used a simple European general grease. I guess that lithium grease should work OK.
    Here is diagram how I got that silly part on the horizontal shift lever shaft. (attempt at own peril)
  10. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    thanks much.
    is the plastic stationary/attached?
    should the ball head be greased?
    what exactly did you push down instead of sideways and break? seems it could only be pushed through sideways
  11. Shh1966
    Shh1966 Rookie
    Mar 16, 2016
    5
    Replaced bushing with Hill Engineering part (71.00 from Ricamba), and shifts perfectly now. Great pics and instructions. Took me about an hour and a half. As I lifted the shifter out, half of the plastic bushing fell off. It was completely broken. The most difficult part for me was getting the little square plastic part off the end of the thru shaft, it was stubborn but didn't break.
  12. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Great to see this thread still active since 2009 :)
    I sold that car a few years back, sure do miss her!
    Anyone that has shift issues - try this fix. It really is not that difficult!
    Chris
  13. DougDish
    DougDish Karting
    215
    Northern NJ
    Doug
    #113 DougDish, Sep 4, 2017
    Chris' legacy lives on in 2017. Completed the part change myself today. I removed the shift box casting from the vehicle, was easier to clean and replace all the grease without worrying about the cabin interior. Shifts were difficult from 1st to 2nd and now resolved.
    Thank you.
    Doug
  14. Dewinator
    Dewinator F1 Veteran
    7,361
    WA
    When I first pull out of my neighborhood, the shifter doesn’t seem to like changing very much. I sometimes have to go back to neutral with clutch out and try again to avoid jamming it in.
    Once I’ve been driving a few minutes it seems to warm up and everything is fine. Could that be a sign that it’s time for new bushing or something else?
  15. Joe Sommer
    Joe Sommer Rookie
    Apr 19, 2019
    19
    This is a fantastic write-up and documentation of the common problem of the wearing/broken OEM shift bushing. I experienced the same symptoms (irregular difficult blocked shifts into 2nd and 1st gear even at low rpms, 5mm+ lateral play in shift lever). I ordered a Hill bushing from Daniel at Ricambi and had my indi switch it out. Car shifts perfectly now and there is no longer any lateral play in the lever. Very pleased with the results.
  16. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    18
    Sweden
    Peter Dahlstrom
  17. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    222
    Dan
  18. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    904
    S La
    Was something wrong with the cables? I too had the balky shift problem when I bought my 2002 360 in 2012 with 13K miles on it. The linkage had a typical hairline crack and I replaced it with the billet metal Hills bushing and it has been perfect ever since with 27K now on the car. I did not mess with the cables at all so that is why I wondered why you were replacing the cables.
  19. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    222
    Dan
    The technician indicated that the cables were worn. Good to hear that the hill part has served you well for so long. My 360 was coming on 40,000 miles, and looking through the extensive service history I didn't see the repair before. Hoping for another 40k before opening up that box again
    Kevin Rev'n likes this.
  20. 24000rpm
    24000rpm F1 Rookie
  21. LorenzoR
    LorenzoR F1 Rookie
    I'm curious why you removing the center piece
  22. 24000rpm
    24000rpm F1 Rookie
    Need to replace the center piece, it has a lot of play and was worn
  23. LorenzoR
    LorenzoR F1 Rookie
    If I remember correctly that part that you have circled has to be tapped out by using a punch or whatever you can get in there. Taking that large nut out from the other side helps give you more room. I don't know why that damm thing is so tight in there. When I built mine I could hardly get that new bushing in so i reamed that hole out with some emery cloth
  24. 24000rpm
    24000rpm F1 Rookie
    just removed the large nut on the other side, it gives maybe 1/8 inch of room in there.
    so do I tap it from inside of the square, tapping it out, correct?
    That means I have to tap it at an angle?
  25. LorenzoR
    LorenzoR F1 Rookie
    #125 LorenzoR, May 26, 2022
    yes hit it slightly at different spots. see if it will move. There's no other way. If you look up the part number and Google it you will see what it looks like . It might be a good idea to do that 1st that way you have an idea of what the part looks like and what you're doing.
