News
360 spider flaps wont come up
Discussion in '360/430' started by 900ssDuke, Sep 25, 2009.
  1. 900ssDuke
    900ssDuke Karting
    Sep 12, 2007
    214
    When the soft top folds away, the last thing to happen is that the flaps either side should come up. They dont. They are cable operated vie a small motor. I have played about with the limit switches I can find. Does not seem to make any difference. If I take the car for a run with the flaps down (which means the windows are not closed), after a while it behaves. Anybody any ideas. Anybody know if there is a particular limit switch I need to look at. I have lubed the flap rails. regards
  3. djastral69
    djastral69 Formula 3
    Aug 6, 2007
    1,858
    Fl
    David
    check your fluid levels in the hydraulic fluid reservoir in the inside panel behind the passenger seat.
