Buy
360 spider not starting
Discussion in '360/430' started by udalmia, Mar 17, 2004.
  1. udalmia
    udalmia Guest
    Hope this is a teething problem
    We left our 500 mile 360 spider in the garage for 2 days ( its heated if that matters) and i try to start it today morning but no go! When i turn the ignition, diagnostic shows check OK and then displays the ASR logo striked across...
    When I turn the ignition to the position 3, the car makes a Putt-Putt noise, i can hear the engine noise for like a millisecond but then it makes a "stuttering noise" after that.. dead battery maybe?
  3. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    Are you sure the alarm is off? Your description of the car trying to start matches the way the car sounds when the alarm is still on.
  4. udalmia
    udalmia Guest
    yep i made sure the alarm was off.. i called the folks at classic coach, they think the battery's dead.. oh well it had to go there to get the roof issues fixed anyway
  5. Cavallino Motors
    Cavallino Motors F1 World Champ
    May 31, 2001
    14,143
    Florida or Argentina
    Martin W.
    put gas in the car?
    maybe the gas gauge is broken?
  6. udalmia
    udalmia Guest
    its on a full tank of gas martin its a brand new car.. well not exactly brand new, the owner had it sitting at FLI for a while, so it could be the battery i guess
  8. johnw
    johnw Formula Junior
    Jun 19, 2002
    438
    toronto
    john
    i'm pretty sure it 's a dead battery. my new 360 did that right from the showroom floor. it only held a charge for about two days then wouldn't start.
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    These car suck down batteries. If you don't drive it every day use a tender. If you never plan to drive it this isn't a problem.
  10. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Did you press the key fob before starting the car? If the engine won't crank over, press the key fob (beep, beep) then try again. If it doesn't work, it's probably the battery.
  11. udalmia
    udalmia Guest
    Yep Willis I did, the alarm was off (the red light to the left of the steering was no longer blinking )
  13. udalmia
    udalmia Guest
    Someone was telling me I can recharge the battery in the passenger side, is this possible without a tender?
