360 spyder top not aligning properly | FerrariChat
Discussion in 'Technical Q&A' started by DAVID SIEGEL, Nov 9, 2019.
  1. DAVID SIEGEL
    DAVID SIEGEL Karting
    Jun 12, 2019
    72
  2. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    I had one doing that before, it turned out to be a loose micro switch. If you look carefully at the hinges near the rear of the cassette you will see micro switches that signal the roof when it is time to begin the next sequence, if the micro switch does not close the roof should stop working completely to prevent damage. However a loose micro switch will move around and close at the wrong time. The ones you are interested in are very visible, just check them carefully and see if they move around at all they should be fixed in an exact position and not move on the hinge. Also look carefully if the long tang on the switch is bent at all it should be pretty obvious. Check with the top completely open and the rear engine lid up.
    2NA and Qavion like this.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    The canvas on the top is not folding correctly due to either bad elastics, or cable..
    BOKE and 2NA like this.
  4. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    +1
    The bar to keep it folded properly is not being pulled back and into position because the elastic bands are too loose.
    BNDT. This issue and how to resolve were mentioned before in other posts. Search is your friend ;)
    BOKE likes this.
