360 Starting ''issue''.... | Page 3 | FerrariChat
Discussion in '360/430' started by 993turbo, Feb 8, 2014.
  1. fatbillybob
    Aug 10, 2002
    29,272
    socal
    you need reliable data in order to diagnose. So you will need to figure out a way to get that. You are either lacking spark or fuel or both when the car runs on 4. You need to figure that out first otherwise you are guessing at possible causes hoping to get lucky.
  2. Black360
    Black360 Formula Junior
    Oct 11, 2010
    454
    East of Eden
    Any thoughts about why there are no misfire codes?
  3. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Yes, of course. Its very simple. It does not misfire. The whole bank is dead (if my teory is correct), and thus the ECU is not reading anything. Its just starting up a few secs after the other bank.
    :D
  4. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Im fully aware of that. However, I think I have gathered more reliable data than most before on this issue.
    My next step is the following:
    Start the car, run it for a few secs on what I think is only one bank. then i will IR gun the exhaust ports to check which cylinders have fired.
    Should get a fairly good indication if a whole bank is missing, and if so, which one...
    :D
  5. Black360
    Oct 11, 2010
    454
    East of Eden
    #55 Black360, Feb 16, 2014
    I was under the impression that each ECU monitored engine speed, and detected misfire based upon RPM change between two anticipated firings. In other words, I thought that two adjacent events defined misfire, regardless of what happens afterwards.
    Perhaps I'm missing something; maybe my brain needs a reflash :)
    (The graph below is for a Bosch ME7.4.4 ECU; the 360 uses an ME7.3)
  6. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    I will revert after I determine if it actually is starting up on just one bank, and if its the same bank every time.
    In the meanwhile, I think the answer to your question is that each ecu stores the misfirecodes for its own bank only. The engine ECUs are set up like two 4cyl engines.
    :D
  7. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    I don't know how quickly a misfire will result in a code or CEL activation. I've had misfiring issues on a couple of times on my 2000 Euro 360 and never had CEL or stored codes as a result. Perhaps it has to misfire for an extended period of time or is only measured above certain RPM or something along those lines. I certainly don't think it's instantaneous anyway.
  8. Cyt
    Cyt F1 Rookie
    Feb 1, 2014
    3,767
    Cyt- Chin
    What's the outcome on this? Have you managed to fix the issue?
  9. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Nope, still the same....... Having said that, I havent used the car too much lately. Both my 360 and the 430 is acting up.... haha, always something.
    :D
  10. Cyt
    Cyt F1 Rookie
    Feb 1, 2014
    3,767
    Cyt- Chin
    My 360 has the similar start up..:(
  11. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Have you changed the battery?
  12. Cyt
    Cyt F1 Rookie
    Feb 1, 2014
    3,767
    Cyt- Chin
    Not touch the battery..
  13. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    That would be my first port of call followed by the relays. There's another thread on here where this issue has been resolved with a fresh battery. These cars really are sensitive to weak batteries.
  14. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Mine has a new battery. Bosch. Charging system all in order. Always kept on a Ctek when not in use. The problem remains.
    :D
  15. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Just as an update, I have a thread on one of the other F-forums, which have been running since 2008 in fact.
    Another member there had a similar issue, and it was rectified by swopping the ignition ECUs left to right side........ Go Figure.
    I will try this swopping over the ECUs when I get home towards the end of May.....
    :D
  16. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,124
    Calif
    Brett
    Hey Kevin...get off the forum and drive that thing will ya?? I've put 6000 on mine since last August when I bought it!
    Cheers!!
    Ps : or is that 1,006,000???
  17. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    I tried swopping the ECU's left to right. No change at all.
    Next check:
    -I have now bought a 2nd fuel pressure tester, so I will have a pressure gauge connected to each bank during start-up to see if there are any differences.....
    :D The saga goes on. :D
  18. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Ok, I have now done the startup with 2 fuel pressure testers connected. One to each bank.
    Both banks prime up the fuel pressure to factory specs when the ignition is turned on. Both banks hold the same fuel pressure during cranking and start up. No difference in Fuel Pressure left to right.
    The mystery continues. :D
  19. vrsurgeon
    vrsurgeon F1 World Champ
    16,598
    Charleston, SC
    Curt
    Do you think the relay for ECU on the one side that isn't running might be sticking or not engaging on startup immediately? If you switch the ECU relay from side to side.. do the symptoms follow? Relays 55 and 88?
  20. Black360
    Oct 11, 2010
    454
    East of Eden
    Has anyone:
    1) Disconnected their 360 battery, and left it disconnected for a while
    2) Found that the engine runs very rough upon restart
    3) Allowed the engine to run roughly, and found that the engine resumes normal operation after a few minutes?
    Mimmo Blue likes this.
  21. Skidkid
    Skidkid F1 Veteran
    9,632
    Campbell, CA
    John Zornes
    Did you go through the learn process. The engine management system needs to go through a learn process. Happens every time you disconnect the battery.
  22. Black360
    Oct 11, 2010
    454
    East of Eden
    From your statement above, I infer that you have had the same experience as me.
    Yes, the injectors go into "learn mode" after power has been disconnected (and left disconnected for a while); see my post (#33) in this thread.
    When power is disconnected, the ECU loses electrical potential, and the injectors go into learn mode, on the next start-up. At start-up, I believe that the injection time defaults to maximum, as a result of the lost potential. I can explain, if anyone is interested.
    In post #35, the OP states that the engine runs the same (i.e., it runs poorly) after leaving the battery disconnected over night.
    That makes sense to me. Because in either case, I believe that the ECU is losing potential, and the injectors are going into learn mode.
    If you buy the theory that the ECU is losing potential in either case, the question becomes "How does the ECU lose potential without disconnecting the battery?"
    If anyone is interested, I'll post my answer to the question above.
  23. star4747
    star4747 Formula Junior
    Dec 28, 2010
    363
    Midwest - USA
    Rick
    This is the procedure after battery has been disconnected / replaced
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1458653&d=1327817612
  24. Black360
    Oct 11, 2010
    454
    East of Eden
    Thanks.
    The procedure given in the FWM (see Post #33 of this thread) has always worked fine for me.
    Perhaps I should mention that the OP of this thread is not having a problem with reset. His problem is that the car runs poorly upon start-up, after an overnight cold soak.
    My WAG is that the ECU is loosing potential, causing the injectors to go into learn-mode upon start-up.
  25. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Sure, shoot. :D
