I'm posting this for a colleague who has a 360. Does anyone have a source for thermo couplers (or exhaust temperature probes for the cats). Apparently Ferrari wants his house and kids for them LOL
I shopped around and found the front ones at autozone for $109 a piece. Simply search the part # and then call around. Amazing differences in pricing.....they are standard Bosch parts
Hmmm...looking it up I think those were the front o2 sensors. Ricambi has the thermocouplers. TSTCPLV8 - THERMOCOUPLE / PATTERN FIT V8 (F355, 360) * SOLD IN QUANTITIES OF 2X ONLY * Adjustable installation length K type thermocouple suited to various Ferrari catalytic converter temperature measurement applications. Output matched to factory specification. Simply adjust installation depth to locate the tip in mid-stream of exhaust gas flow and tighten compression nut to secure the thermocouple location. Adaptable to factory and after-market catalytic converters. Supplied with brass ferrule and stainless steel compression nut. Tested to fit F355 and 360. Replacement for Ferrari parts 157501 and 193467 FROM TECHNISTRADA / NEW ZEALAND Skip to the end of the images gallery Image Unavailable, Please Login TSTCPLV8 - THERMOCOUPLE / PATTERN FIT V8 (F355, 360) Skip to the beginning of the images gallery Ask a question about this item $29.00Each
Yes, I was mistaken there. My front o2 sensors needed replacing for a smog issue here in calif. I have changed my thermos also because of the intermittent slow down light.
It's either the thermocouples or the thermocouple ECUs causing the SD light to come on with the engine still cold. The best value for aftermarket thermocouples seems to be Technistrada (see post #4). Technistrada also make aftermarket thermocouple ECUs or "Catalytic temperature control station" as it is also known (Ferrari P/N 179278): https://technistrada.com/catalytic-temperature-control-station---355-360-456-550-575 Ratarossa on YouTube has a video on diagnosing SD problems.
Probably best to ask @AceMaster .. but why would a secondary air pump issue cause an SD light with the engine cold?
the 2ndary air pump comes on when the engine is cold to force air into the headers to encourage the cats to come alive
Understood. One of the functions of secondary air is to help heat up the cats more quickly, but isn't the SLOW DOWN light primarily used to indicate excessively high exhaust temperatures? If the 2ndary air pump is not working, wouldn't the exhaust system not heat up more quickly (but also throw a CHECK ENGINE light)?
many times a slow down CEL comes from the thermocouples not correctly reading even though the exhaust temps could be OK so there is either a temp imbalance or bad thermocouple apparently I would think a CEL should come up if pump does not come on I had a bearing go bad in a 2ndary air pump. The pump worked noisily until replaced. So I never got a CEL for that this scenario sounds like the dog chasing his tail
Holy crap this sounds great! I just got new cat ECUs but didn’t know about this one. Looks like a cheaper way to do it, and does it cheat the motor ECU concerning voltage and temp? Would love to chat with business owner about this if you’re here!
Not at all. It replicates the OEM electronics precisely using sturdier electronics. The unit is smaller and ligher. The casing may not be as "polished-looking" as the OEM, but it does the job. See the website pics for reference. Technistrada does make a dummy ECU for "no cat" applications, but this will not work on the 360 (only on earlier cars, such as the F355). This is a "cheat", but works well on the earlier cars without cats.
Does anyone know a way of installing these without taking half the back end apart. This 360 has stock exhaust.
If you can get to the nut at the end of the cat, why not cut the wire heading to CAT ECU, and install new thermocouple the way you want to? Does it really have to be fastened at the bottom of the air box?
I will ask the owner, I am not the owner of the 360 (I own a 348), I am just doing the leg work for him as he is not a member here on FChat...thanks.
