360 Timing bearing grease. | FerrariChat
Discussion in '360/430' started by skar89, Nov 29, 2017.
  1. skar89
    skar89 Rookie
    Feb 27, 2012
    13
    Spain
    Hi friends.
    I was doing timing service and noticed that blue grease came out from the bearings. They are both new and car is still in workshop.
    Is it normal or just a bad bearings ?
    Thank you in advance.
    Enviado desde mi SM-G950F mediante Tapatalk
  2. vrsurgeon
    vrsurgeon F1 World Champ
    15,916
    Charleston, SC
    Curt
    Why not ask your mechanic who is DOING the service instead of strangers on the web?
    If they're new bearings then why are you concerned?
  3. skar89
    skar89 Rookie
    Feb 27, 2012
    13
    Spain
    Im mechanic, first time doing timing in my 360. Im asking here because is a Ferrari forum with helpfull people.
    Both are new, but even new they can be in bad condition.
  4. vrsurgeon
    15,916
    Charleston, SC
    Curt
    So how will you ever know if you have a bad bearing? Even if it doesn't have grease on the outside it can be bad. You could be replacing a good bearing with a bad one that "looks perfect".
    I presume it functions perfect right? (This is absurd.. install and monitor and check in a thousand miles IMHO.. but please let's let some others chime in here)
  5. skar89
    skar89 Rookie
    Feb 27, 2012
    13
    Spain
    OK ok. The bearings came perfect and the grease came out while warming the engine and testing.
  6. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    Looks like they have plenty of grease. You don't want it on your timing belt. Wipe and go.
    skar89 likes this.
  7. vrsurgeon
    15,916
    Charleston, SC
    Curt
    If it were me I'd check they move fine with no binding or sticking and then install. I'd then check them if I hear any noises or odd sounds in a few hundred miles in the event you over tightened them and then if there are any noises in the next few years.
    Congrats on getting the job done! :)
    skar89 likes this.
  8. skar89
    skar89 Rookie
    Feb 27, 2012
    13
    Spain
    Thank you two.
  9. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,694
    Melbourne Florida
    KGC
    Someone else has posted the same issue a few months back. You may want to do a search.
    skar89 likes this.
  10. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,342
    On the Limit
    Dino
    That doesn't look normal to me.
    skar89 likes this.
  11. honda.vfr
    honda.vfr Karting
    Jun 22, 2012
    134
    Ostrava, CZ (EU)
    Milan Pukl
    Looking at the gap between tensioner and the lever I would just say that the problem is in over-tension. Overstressed parts obviously overheat..
    skar89 likes this.
  12. dreichman
    dreichman Formula Junior
    Sep 9, 2011
    425
    Denver, CO
    Good bearings don’t leak. I would return them as defective and ask for a new set. Hopefully it won’t be a problem. Good luck!
    skar89 likes this.
  13. skar89
    skar89 Rookie
    Feb 27, 2012
    13
    Spain
    Tension was measured in HZ, between 190 and 220. Other thing is that tensioner compresses little by little after starting engine and belt loses tension, but never over tensioned.
