360 variator issue | Page 2 | FerrariChat
360 variator issue
Discussion in '360/430' started by southpaw802000, Nov 4, 2012.
  1. AndreB
    AndreB Karting
    Jun 8, 2018
    246
    HTX
    Ndr
    Even if you take the car to a dealer how could they confirm? I would assume they run the vin in the db and spit out whatever it says...
  2. cb2me
    cb2me Rookie
    Mar 12, 2021
    16
    Central PA
    Exactly - that's what the Philly dealership did already. No record of the vehicle....maybe because it is a Euro spec? But with 30K+ miles on it, it should have failed by now, right?
  3. AndreB
    AndreB Karting
    Jun 8, 2018
    246
    HTX
    Ndr
    There is a silver 360 for sale in colorado with 30k miles in the same situation.
    “it must have been done if it now has 30k miles”
    but when I talked to some mechanics they told me “not necessarily “.
    A risk I may take on a Porsche 996, not sure on a 360...
  4. Skidkid
    Skidkid F1 Veteran
    9,660
    Campbell, CA
    John Zornes
    Generally yes. If it was going to fail it probably would have. And the change was very small since there isn't a lot of room to add more metal there. But obviously there are no guarantees in life and even post campaign variators have failed.
    Prices now have a pretty big spread, It is all about condition. Sure, euro v US car has some spread but it isn't as big as it used to be, I would guess closer to 5K or a bit more.
  5. brookliner7
    brookliner7 Formula Junior
    885
    San Antonio, TX
    Hans
    Can physically look at the variator, replacement ones for the campaign have a Green Dot painted on them
    AndreB likes this.
  6. Skidkid
    Skidkid F1 Veteran
    9,660
    Campbell, CA
    John Zornes
    True. At least as I understand it.
  7. Mikestradale
    Mikestradale F1 Rookie
    Jan 25, 2006
    2,624
    Netherlands
    #33 Mikestradale, Mar 15, 2021
    The cambelt variator on my 2001 Euro 360 Spider failed in 2012 at 67000 km. Chassis number #125348. That was an expensive day ($10k+).
    But at least I have a bunch of nice souvenirs for my mancave now. The Ferrari service shop even painted one of them in a nice colour for me :)
  8. F1Pete
    F1Pete Karting
    Sep 2, 2021
    65
    Ca
    Is this upgrade still covered by FNA, if NOT performed on your car? or is it passed the period of the service campaign?
  9. cb2me
    cb2me Rookie
    Mar 12, 2021
    16
    Central PA
    My understanding is that it has passed the period of the service campaign - I went ahead and had mine replaced as it was within the VIN and Engine # range. Was told by the tech it could have failed at any time even though it had 30K+ miles on it. $4500 for peace of mind!
  10. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Had mine done last year mine is a 2000 euro
    Front cam seals rear cam plate seals
    Valve cover gaskets
    Hill Bearings
    Belts
    Tensioners
    Passenger side Tensioner bracket update
    Had one other Tensioner part that failed also
    Variators
    Total price was $8700 Image Unavailable, Please Login
    Sent from my SM-G996U1 using Tapatalk
  11. one4torque
    one4torque F1 Veteran
    5,798
    Houston
    One4torque
    02360- that’s not too bad
    I was quoted 15-20k … still looking for a viable option in Houston.
  12. G8TD
    G8TD Karting
    119
    Houston
    Joe
    What exactly were you having done for that amount?
  13. one4torque
    5,798
    Houston
    One4torque
    G8t- that was belts tensioner and variators.
  14. cb2me
    cb2me Rookie
    Mar 12, 2021
    16
    Central PA
    Pocono Sportscar (former Ferrari dealership tech in PA) replaced belts, tensioner and variators for the price I mentioned (labor + parts). I think that's where you need to be - around $5K.
    one4torque likes this.
  15. one4torque
    5,798
    Houston
    One4torque
    Just need to find someone in Hou area in this price range.
  16. G8TD
    G8TD Karting
    119
    Houston
    Joe
    Have you talked to Haris at H&S Motorsports? Haris did a 30k major on my '04 360 earlier this year. Belts, tensioners, variators, water pump rebuild, brake service, etc. for $8500. I have no affiliation with the shop other than being a satisfied customer.
    I've put 2,000+ miles on my car since the work this spring. The car runs great and I'm not as concerned when operating near 8,500 rpm on occasion.
    Feel free to give me a call if you want more information about my experience.
    Joe
    (616) 350-2146
  17. one4torque
    5,798
    Houston
    One4torque
    Thx joe! Will look em up when I’m ready to do this work.
