360 Very High Oil Temp | FerrariChat
Discussion in '360/430' started by scottaz76, Jan 13, 2018.
  1. scottaz76
    scottaz76 Rookie
    Apr 8, 2007
    14
    Tempe, AZ
    Scott
    Today I replaced the battery in my 2001 360. I took it to the gas station to fill it up and while driving home I received a high oil temp warning. The gage was maxed out at 280 degrees. When I got home I noticed there was a whistling sound coming out of the engine compartment. I turned off the engine to let it cool and could hear boiling sounds. Once the cars temp went down to 240 the whistling stopped. My guess is the whistling was due to the oil temp, similar to that of a teapot releasing steam. Has anyone else had this issue and know the root cause.
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,438
    Charleston, SC
    Curt
    Your car sounds like it was overheating something fierce! Boiling? Umm Check your thermostat is working and your water pump is pumping. Oil temp only and not water temp high?
  3. mello
    mello F1 Veteran
    5,432
    CA Bay Area
    Steve
    Any visible or fluid level loss?
  4. Cgk360
    Cgk360 Formula Junior
    569
    NJ
    Chris
    I agree with Curt. Coolant will gurgle and hiss. Oil will smoke. It sounds like an engine coolant problem and faulty collateral temp gauge at a minimum. Check fluid level and then move on to water pump, thermostat, etc. qchange your oil while at it as you might have cooked it. Hopefully you caught it early enough and there isn't any engine damage.
  5. PFSEX
    PFSEX Formula Junior
    Jun 30, 2006
    843
    Las Vegas
    John Ratto
    So - oil temp was pegged...what was the water temp doing?????
    If water temp was not high, you may have a bad oil temp sender or gauge.
  6. vrsurgeon
    16,438
    Charleston, SC
    Curt
    I thought the same thing.... but the hissing sound reported made me nervous!
    I wonder.. did the OP read the Water gauge by mistake and think it was the oil? Water gauge is all the way on the left....
  7. scottaz76
    scottaz76 Rookie
    Apr 8, 2007
    14
    Tempe, AZ
    Scott
    Thanks for the feedback guys. I completely misread the gages. It was my water temp gage, not oil gage. Now the hissing and boiling sounds make more sense. Thoughts on what would cause this and what to check?
  8. scottaz76
    scottaz76 Rookie
    Apr 8, 2007
    14
    Tempe, AZ
    Scott
    I also want to note that the oil temp and pressure were normal. I also didn’t see any fluid leaks on the ground.
  9. scottaz76
    scottaz76 Rookie
    Apr 8, 2007
    14
    Tempe, AZ
    Scott
    One more update. I just checked my coolent level and it was barely visible. The manual says it should be 1.5 inches from the top. I am going to fill it up and see if the issue persists.
  10. mello
    mello F1 Veteran
    5,432
    CA Bay Area
    Steve
    The coolant cap is probably shot. If the coolant is not under pressure, the boiling temperature decreases.
  11. TheMayor
    104,768
    Vegas baby
    Oil temp is OK but water temperature is full pegged? I would still look at the water temp sending unit.
    I also agree to replace the radiator cap. They actually do lose their ability to hold pressure over time.
    Start with the simple things first then work up.
  12. knocker
    knocker F1 World Champ
    Jul 10, 2017
    12,288
    Sydney Aus
    Adrian
    Hi mate make shure the coolant is clear n green stick your finger in there when it’s cold make shure no oily slime deposit , if so possibly heat exchanger fail (worst case)my cars heat exchanger failed at 79,000klms
  13. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    911
    Georgia
    Mark Gronsbell
    Consider thermostat being stuck closed as a possible cause
  14. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    Was the coolant changed recently? If so did they properly bleed the system? They can vapor lock at the outlet from the engine and there is a bleed screw there. So many possabilities
  15. vrsurgeon
    16,438
    Charleston, SC
    Curt
    Three things id check personally:
    1) replace the cap on the reservoir as above is likely GONE.( the seem to last a couple years at best) What happens: can't maintain pressure on coolant system and then car overheats as a result. Also accounts for the hissing. Replace it with a new one.
    2) thermostat could be stuck (You'll see it overheat - I'd use one of those IR heat sensors to watch the engine heat up to middle of gauge a and correlate the gauge to engine heat)
    3) Water pump still turning? Leaking?
    4) If you turn the 10mm bolt on top of the thermostat housing does fluid come out?
    f355spider and Skidkid like this.
