360C air jacks | FerrariChat
360C air jacks
Discussion in '360/430' started by ferrarifixer, Sep 13, 2005.
  1. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    #1 ferrarifixer, Sep 13, 2005
    Ok, seeing as 430C will come with air jacks like a 360GT, here's what I've (race team) done to the Aussie 360C cars.
    I've used a big bracket in the front, the idea being to maybe add a little stiffness. This was done at a time when we needed to ballast the cars, and the whole kit installed using rubber lined aeroquip lines weighs about 18kg. The 360GT and 430C use small singular brackets in the front.
    At the rear, rather than use a gearbox mounted central single jack, I used a pair mounted to the frame. This means the car goes up and down squarely at all times. Some trimming to the aero floor is required, but it is only small.
    To support it when it's up, simple folded alluminium "stubbies" are used.
    To control the lift.. a high pressure regulator is needed, a "spike" and an inline tap with spike fitting.
  2. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Thanks Phil. Just what I needed. Have the air jacks already so now I only need to make brackets to fit.
  3. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    No problem. Wayne. happy to help as always.
    If you make smaller front bracket without cross bracing, attack the rear brackets with a hole saw and use teflon lined aeroquip hose you could do it all at about 10-12KG.
    Be sure to heat shrink over ALL the aeroquip line, as it turns into a high speed hacksaw with engine vibrations!
  4. Carreracup
    Carreracup Rookie
    Dec 10, 2005
    14
    Sweden
    Niclas Thorvaldsson
    #4 Carreracup, Jan 10, 2006
  5. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Its steel, and bolted onto the frame with 3 bolts inside the visible deep tubes.
    it's important to keep the jack perfectly vertical in all planes, and the frame is not, so the bracket needs to be angled a little.
  6. Carreracup
    Carreracup Rookie
    Dec 10, 2005
    14
    Sweden
    Niclas Thorvaldsson
    ok..
    Waht do you mean by "Be sure to heat shrink over ALL the aeroquip line, as it turns into a high speed hacksaw with engine vibrations!"?
    Du you have more pic´s? would be great.
    Could u give me a hint of camber,caster,toe. I just bought the car an d the seller did not want to give me any info. i massurd today an had -4 camber witch i tink is good but a positve toe in(toe ut) what i have learn on other car´s that wont do it...
    Many Thanks Nic
  7. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    The stainless steel braids of the hoses will vibrate at high speed, and will easily cut through wires, pipes and chassis components. They must be securely fastened, and covered with soft rubber coating to prevent this.
    Wheel alignment..... what tyres will you use. Pirelli need a quite different set up to Dunlop or Michelin for example.
    Also... what other mods does the car have... wing and/or splitter? Shocks?
  8. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    Will this help stop the car better than the carbon/ceramic brakes?????
  9. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    hmmm...what does air jacks have to do with brakes... ??
    I think you are misunderstanding the topic here.
  10. Carreracup
    Carreracup Rookie
    Dec 10, 2005
    14
    Sweden
    Niclas Thorvaldsson
    Ok i understand...
    I have no modifications on the car. in my race serie it´s not aloud.
    We use Khumo slick in this one tire series....
    Do you knowe what kind of plasttic the aero floor is made in? is it possible to repaair whivth glassfiber or someting.i have smal cracks in it..at a wrong place.
    Niclas
  11. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I have no data for Kumho slicks. So, you will have to do lots of testing!!
    The floor can be repaired, but it must be totally clean... any oil will prevent a good repair, and it must also be scratched up to provide keying for repairs to stick. Use carbon kevlar (not carbon fibre) patches where it touches the ground, it'll save many future repairs.
  12. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    It was a joke.......you know, like stopping the car Flintstone style....... LOL
  13. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Phil:
    Why bother with carbon kevlar repair? The area by the rear anti-roll bar gets trashed so often we just rivet in a piece of aluminum sheet instead? Or will ck standup to the abuse much better?
    And why the bracket is made from steel? I am going to have it made from aluminum. I figure each corner only has to take max 600kg. Or is there something I missed?
  14. fatbillybob
    Aug 10, 2002
    29,053
    socal
    I thought about doing this but conservatively estimated the increased weight at about 50-60lbs for three jacks 2 rear and 1 front. Did you use AP aluminium cylinders?
  15. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    You could use alloy I guess, but it would be more likely to stress fatigue... On one of the team cars, we made the front one from Titanium. Saved 5 kg from the steel equivalent. At the time we made these, we needed to add weight for 1355kg race weight (with driver), so it wasn't a decision to be made.
    The Michelotto front ones are very small and work well, but they don't add any stiffness.
    The jacks we used are bilstein if I remember correctly. Very light and alloy.
    For the floor repairs, the kevlar is much tougher, but alloy is easy, quick, cheap and available.
  16. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    I forgot about the weight penalty. I guess steel is good then. Thanks.
  17. Carreracup
    Carreracup Rookie
    Dec 10, 2005
    14
    Sweden
    Niclas Thorvaldsson
    Ferrarifixer how high stroke du you have? is itaround 270-310mm?
    Nick
  18. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Now now, thats a bit personal isn't it!!
    I'm afraid I only measure up at about 240mm, but I'm happy with that!
    There are special tripod extensions you can use to "double jack" the car if you want increase height.
    Air jacks are only really used to get clearance for changing wheels, and NOT for servicing the car.
    If working underneath, ALWAYS use solid supports.
  19. Carreracup
    Carreracup Rookie
    Dec 10, 2005
    14
    Sweden
    Niclas Thorvaldsson
    Hahaha sorry I´m not so good att your gramatics..
    How mutch is the lift under your tires wivth the 240mm jack?
    Whan i messure ithink i have to use 270mm jack just to get the car off the ground...and then you want some space to change wheels another 30-40mm...or are I out there??? Mabe we don´t use same diameter on the wheel but it shoud not make an 20mm diff?
    Nick
  20. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Well, the jacks are adjustable in height, so I set them to have the same clearance as the lowest part of the car (actually use them as a skid is ok).
    When fully raised, the wheels are about 30-40 mm clear, so that's fine for racing pit stops. If I want a bit more lift for between session prep checks, I just put wood under the jacks before lifting.... 50mm (2")at front, 75mm (3")at rear.
