360CS Cold Start Problem | Page 2 | FerrariChat
Discussion in '360/430' started by RenoCS, Nov 7, 2006.
  1. Under PSI
    Under PSI F1 Rookie
    May 13, 2005
    4,240
    Phoenix
    Jim
    My 360 sputters for about 10-15 seconds when it is started cold and then it runs fine. Is this the same problem? Mine is not a CS.
  2. RenoCS
    RenoCS Karting
    Oct 30, 2006
    83
    Reno, NV
    Robert J
    I don't think so.... Because my CS will not run fine when it first starts up and it will even stall. I have to reset everything and after 2-3 try's, she finally comes to life..
  3. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    That's exactly what my CS does.......
  4. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    For those of you who have had their ECU's reflashed, I have a few questions:
    1) Do you have the factory cats and/or exhaust?
    2) Did the dealer do any readings on the current ECU's before sending them to FNA?
    I have a CS that has the cold start issue, and I have Tubi Straight Pipes (no cats) with a Tubi NGT exhaust. My dealer (Shelton) told me that the only way they can send the ECUs back to FNA to be reflashed is if my cats are on the car so they can read the parameters to send with the ECUs back to FNA.
    This seems like BS, since two things are true....1) Even people with cats have the issue and, 2) this is a COLD start issue, so even with cats, there's nothing to measure since cats are useless until heated up. SO, I am curious what the procedure was for your reflash..........thanks!!!
  5. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
  6. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    fred,
    1. I have factory cats but will change cats soon as warranty is expiring
    2. no, dealer (fosf -- factory store!) suggested I can remove ecu's myself and send them by mail
    3. sounds like typical ferrari bs
    my ecus being sent in this week
    good luck
    mike
  7. amenasce
    34,780
    Joe Mansion
  8. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    andrew,
    it hasn't happened on mine , which is perhaps surprising as it' s an early car. Pot luck i guess :) THe dealer's likely to say wait till it's happened a few times as the re flash is about £800. You still have wrrnty?
  9. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    Hasn't happened to mine either. I assume it won't occur on ours as we have the CS(SP) version.
  10. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    SP :confused: :D
  11. nerd
    nerd F1 Rookie
    Oct 12, 2003
    2,539
    Coronado, CA
    RSK
    Factory stock exhaust.
    Yes. FNA asked for a read-out the ECU firmware revision and the "Check Engine" error code to confirm my car's symptoms indicated the need for the firmware re-flash. If your car shows additional anomalies due to the missing cats, they will see a different set of symptoms.
  12. amenasce
    34,780
    Joe Mansion
    For a few more months ( i think June ).
    I told the dealer about it and they didnt seem to be aware about this flashing ..
    Hows your going ? Still madly in love ? :D
  13. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    What version you have?
  14. SixEight
    SixEight Rookie
    Apr 29, 2007
    18
    just of curiosity, have any of you considered fuel to be one of the reasons for the cold start problem? some high performance bmws, audi, etc have had the same issues with ethanol blended gasolines.. (just as a thought) :)
