360CS RH bank no fire | FerrariChat
Discussion in 'Technical Q&A' started by erik stearns, Jul 6, 2025.
  1. erik stearns
    erik stearns Rookie
    May 9, 2013
    2
    RH bank of the engine is not getting fuel. Just getting started. Trying to find a little help vs starting at ground zero. The fuel rail has fuel pressure, have not checked spark yet, however I did pull a plug out and it is dry, no fuel at all.
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,271
    Ian Riddell
    Fuel pressure in the rail means your immobiliser and crank sensor are ok.
    Try swapping the left and right Master Motronic Relays behind the seats. These provide 12volts power to the coils, injectors and cam sensor. Also check fuse 41 (green) as shown below. Fuse numbers and relay numbers may vary from car to car, but the location is the same.
  3. Qavion
    Feb 20, 2015
    14,271
    Ian Riddell
    The problem may be more localised than power coming from the relays, but let us know how you go with the relays and fuse.
  4. Phelips
    Phelips Karting
    May 30, 2025
    66
    Russel Phelips Brown
    Check the injectors on the RH bank could be a wiring issue, bad connection, or clogged injectors. Swap LH and RH injectors to see if the problem follows. Also, test for spark while you're at it. If injectors are firing, might be a ECU or fuel map glitch.
  5. Qavion
    Feb 20, 2015
    14,271
    Ian Riddell
    How often do all 4 injectors fail simultaneously?
  6. Phelips
    Phelips Karting
    May 30, 2025
    66
    Extremely rare unless there’s a common cause (bad fuel, wiring, or ECU problem). Test one at a time. Keep it simple.
  7. Qavion
    Feb 20, 2015
    14,271
    Ian Riddell
    yep, that's why I questioned swapping the injectors. There are lots of easier steps first.
  8. Phelips
    Phelips Karting
    May 30, 2025
    66
    Exactly injectors are a last-resort move. Start simple: check plugs, coils, fuel pressure, and clean the MAF. Cheaper, easier, and often the real culprit. Save the injector swap headache for if those don’t solve it.
