New Birdman Ferrari tutorial Available: CV joints | FerrariChat
Discussion in '308/328' started by Birdman, Apr 3, 2012.
  1. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hey Gang,
    I had to pull one of my drive shafts and replace a leaking transaxle seal, so I decided to rebuild both CV joints, and document the whole thing. David "Fastradio" Feinberg and a few other Ferrari buddies came over to help. We demolished some donuts and David gave me the "rebuilder's 101" on CV joints as well as the proper way to replace the seal in the driver's side of the transaxle. I took pics and wrote it up in order to add it to the growing list of service procedures I'm archiving at Birdman Ferrari. Check it out
    http://www.birdmanferrari.com/service/cv_joints/cv_joint.htm
    Comments are welcome.
    Birdman
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Great write up. One question about this line and it is self evident:
    DSC discussion:
    "You can use a little silicone to lube it so it goes in smoothly. You do not want to use lubricant like silicone,..."
    So, which is it? Use silicone or not?
  3. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Excellent write up!
    I believe the WSM specifies 140 grams of grease in the joints though.
    A very minor detail: AFAIK only the left hand inner joint has the extra washers on the bolts.
  4. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Nice write up.
    This is a nice one to save for the time where I'll need it.
    I'm sure David is listening in somewhere. Any significant differences for the 328 with this procedure?
  5. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    #5 i-velocita, Apr 3, 2012
    Thanks Bird. Very nice.
  6. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Really, Really good writeup! Thanks to David and Birdman for their time/efforts...
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Agree, that Birdman can write!
    It does. Lobro makes the 108mm CV joints which were used on many super cars in the day. They specify 100gr for this joint, as do all the other manufacturers who used this joint in the late 1960s through 1980s. The WSM has many errors, this being one of the more minor ones...
    Correct. Perhaps better stated, only the LHS inner CV bolts have washers on them, in addition to the semi-circular thrust washers.
    Identical
    You're welcome. It was a fun day! The Birdman and crew did all the hard work; dis-assembly and cleaning. All I did was show them how to put it all back together... :D
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Sorry, that is a little confusing. I'll have to fix that tomorrow. That's what happens when you write too fast. You are lubing the seal with RTV basically. The idea is that you DO NOT want to lube with something that stays slippery like oil or silicone spray. RTV is slippery when you install the seal, allowing it to slide into position without warping or kinking, but then later is no longer slippery, so the seal will not want to move.
    Hey man, I only did the left rear! When I do the right rear I'll post an addendum!!! :D
    Birdman
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    It is a great tutorial for us beginners, thank you.
  10. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Perfect timing again, as I've got to do the right-rear. Thank you all, guys. You continually rock.
  11. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Well done Bird :) Now...can you now do a write-up on brain surgery...? Jeez...where do you fellers get this knowledge, anyway? Truly a wonderful acumen to possess ;-)
  12. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Slacker! You have 2 arms you know..... :D:D
  13. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    No wonder it was so damn difficult to get 140g in when I did mine then!! :(
  14. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    #14 Matto, Apr 26, 2012
    I'm happy to say that David's (fastradio's) complete CV boot kit arrived in today's mail. A terrific value. I'm looking forward to getting those joints cleaned up and resealed. I'll make good use of the tutorial.
  15. shashi27
    shashi27 Formula Junior
    Jan 7, 2006
    988
    Long Valley, NJ
    Shashi
    Does anyone have the torque values for the six nuts on the DSC? I couldn't find it in the WSM and quite frankly I don't really trust the WSM. Thanks.
  16. PT 328
    PT 328 F1 Rookie
    4,016
    I believe Birdman's write up states 57 ft-lbs at the bottom of the article.
  17. shashi27
    Jan 7, 2006
    988
    Long Valley, NJ
    Shashi
    Hi, Isnt he talking about the CV flange to axle bearing bolts? I'm referencing the DSC cover (with new seal) bolts. Thanks.
  18. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    #18 robertgarven, Feb 9, 2013
    Birdman, Great rite up!
    David,
    What is the purpose of the extra LHS inner CV washers? I was not aware of this and only used the same components I took off. Are the thrust washers you are talking about the semicircular metal pictured below? Should I be worried I dont have these. Where do they go on the bolt end? The parts books dont even show the semicircular bits? I have done this 3 times and was not aware of them.
    Thanks,
    Rob
  19. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    I believe its just a clearance issue Robert - the washers go on the hex head side of the bolt on top of the long/semi circle washers in your picture & thereby ensure there is a bit less bolt/thread sticking out the other side (where the nuts go) to make sure the ends of the bolts don't catch on the ends of the studs sticking out the diff housing
  20. robertgarven
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
  21. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    Thanks Birdman for the great write up.
    CK
  22. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
  23. dwhite
    dwhite F1 Rookie
    Having changed all the boots on my CV joints, I can only think one thought; has anyone ever seen more grease in one place .
  24. F308fan
    F308fan Karting
    May 7, 2017
    168
    Peoria, AZ
    Tony Pacini
    Is David F
    Is David Feinberg still selling these kits? How about the double lipped drive shaft seal mentioned? If so, how may I reach him?
