365 GT oscillation? | FerrariChat
365 GT oscillation?
Discussion in 'Vintage (thru 365 GTC4)' started by jww427, Aug 12, 2017.
  1. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Hello!
    On my 365 queen mother, it bounces quite a lot--2 times per second I reckon--when driving from 15mph-45mph.
    Is this a result of the self leveling rear suspension?
    If so, is there a kit to do away with it?
    Thanks!
  2. TTR
    TTR F1 Veteran
    5,200
    Riverside, CA
    Timo
    Could be, but at least shocks are probably shot.
    Probably several types.
  3. srslusso
    srslusso Formula Junior
    Mar 17, 2005
    874
    Encino,Ca.
    Steve S.
    Rear shocks working or not self leveling or load levelers
    Usually will not cause this problem. Check front end alignment
    Wheel balance drive shaft axles etc what happens above that speed ? The car handles
    Better with rear shocks then the expensive rear load levelers that it left the factory with
