365 GT4 2+2 front foglights | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by TomTomGTA, Apr 27, 2021.
  1. TomTomGTA
    TomTomGTA Rookie
    Aug 28, 2012
    20
    Luxembourg
    Tom Mailliet
    Hello there,
    I couldn't find anything with the search function so I'm asking:
    How do you access the front foglights behind the grille to change the bulb? And do you know which bulb goes in there?
    Thanks a lot in advance!
    Tom
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    If you do have the Ducellier fog-lights, these do not have the H1 bullbs like the headlight. From memory mine were fitted with H3 bulbs. The bulbs are not installed horizontally but vertically (tip on top instead of tip in front). This implies to have some bulb with a narrow lateral beam.
    For this reason most led bulbs do not work. Even the halogen 100w "rallye" bulbs do not work properly as the filament is to wide, so the beam is not sufficiently focused, and actually produce much less output than a good 50w bulb.
    If you have the wide front grill blocking the access to the fog light, removing a rusty fog light bezel is difficult. In this case you may have to remove the grill (4 screws)
