365 GT4 2+2 under resto | Page 3 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Cazna, Oct 23, 2014.
  1. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    #51 Arvid, Mar 21, 2016
    Probably leaking from or around the hex aluminium plugs. The casting towards plug hole is very thin and can crack,causing fluid to leak. The cracks are thin and hard to see but they are there.
    I tried using some plumbers tape on the threads but the plug is not long enough to reach the crack. To much tape and the crack will expand,not ideal. Next step will be some good leak sealant product,although I will happily go around this if there's another better solution.
    Maybe some longer hex plugs are available in either aluminium or brass ?
  2. Cazna
    Cazna Karting
    Aug 6, 2013
    72
    Sydney, Australia
    Robert
    Where on the head/motor are the hex plugs?
    There is no obvious sign of them. Mind you the motor is complete with all spark plug leads etc in place so not much to see.
    The radiator fluid is filling around the spark plugs and I just cannot see where it's coming from?
  3. Arvid
    May 28, 2012
    668
    Norway
    Arvid Andersson
    Mine is leaking into plug hole 8. The allen key headed plug is between cyl. 8/9,but leaning more to the nr.8. Therefore water seeps into this one. The head of the plug is flush with the engine head and is about 12mm diameter.
    There are several of these plugs and they can all leak. All of mine has been out at an earlier occasion and put back with some sealant. It is obvious that the have been a problem.
    Mind you,my car is a carb 400 GT but I see no reason why it should be any different on the earlier GT4.
  4. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    582
    Australia
    #54 Al Campbell, Mar 22, 2016
    Hi Robert,
    I hope it is an easy fix. I just had a look at my cars (400i) & took a couple of pictures of the plugs - they are down next to the sparkplugs.
    Cheers,
    Al
  5. Arvid
    May 28, 2012
    668
    Norway
    Arvid Andersson
    Thanks for the pictures Al :)
    Robert,as you see the casting between plug and spark plug hole is very thin. I suspect my plugs has been tightened to hard at some point,and as they are tapered they will crack the thin wall.
  6. 365GT4 2+2
    365GT4 2+2 Karting
    Jan 1, 2016
    55
    Essex, England
    Justin R
    Guess what, I have chassis 17363 and gave it a run today and it has developed the same problem. I mopped out the coolant around the plug and gave the car a good blast at up to 100mph, no more coolant appeared. Clearly we need to get our heads together on this one !!! I wonder if other 365 models are affected ? I tried a search but nothing popped up.
    I also have acquired a Voxson stereo 8 which works beautifully. Interestingly I have a Radiomobile that is identical (says Voxson on the case !) so clearly Voxson sold them to Radiomobile. I am now enjoying re-aquiring all my old 8 tracks from e-bay, particularily Sammy Davis Jnr, as apparently he had one of our cars !
  7. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,915
    North Qld
    simon klein
    I have 6 carbys,4 overhead cams and 4 exhaust pipes.
    I do not know how to turn on MY Voxson 'cos I'm VEEERRY happy listening to the above's music....:D
  8. Cazna
    Cazna Karting
    Aug 6, 2013
    72
    Sydney, Australia
    Robert
    Good stuff.
    If anyone can recommend apart from eBay where to get more 8 track cartridges I'd welcome this. Looking for 70's period music to go with car like Stones, Jefferson Airplane, Miles Davis etc.
    Thanks Al for the excellent photo.
    As Justin shared, it appears to be more common than I've ever heard before. It would make sense when the motor is hot and the metal expands, the leak stops.
    It was very weird to observe it first hand as I start the motor every month whilst the resto is underway and make sure I get water and oil to operating temp as well as roll the car to get crown gears and others moist with oil etc.
    This time would not start then plenty of green water in three spark plug pots.
    I'll try and remove plugs and replace. Thanks boys.
  9. 365GT4 2+2
    365GT4 2+2 Karting
    Jan 1, 2016
    55
    Essex, England
    Justin R
    Update on that coolant leak. Recently took my car (17363) out of storage to start re-commissioning. On starting up I rapidly realised there was a major leak of coolant which was coming from the heater control valve. Sourced a replacement and fitted with a fair amount of dexterity required !! I then carried out a pressure check and found that above 10psi there was a tiny leak of coolant as near number 8 plug as discussed above, it was just like a bead of perspiration . On closer inspection there is a minuscule hair line crack about 15mm away from the hex plug. I decided to try "K seal" which I know from past experience to be a permanent solution to such problems and hey presto it fixed the problem !!! Sadly I should have photographed it before the fix.
  10. Cazna
    Cazna Karting
    Aug 6, 2013
    72
    Sydney, Australia
    Robert
    Can anyone recommend or advise what the original front windscreens were on the 365 GT4 2+2? Clear or green tint on top?
  11. 365GT4 2+2
    365GT4 2+2 Karting
    Jan 1, 2016
    55
    Essex, England
    Justin R
    Mine has the green tint on top. I am in touch with the original owner ( who was only 25 when he bought the car in 1973) so I'll see if he can remember how it was then.
  12. Jim575
    Jim575 Karting
    Sep 26, 2011
    175
    Sydney Australia
    Jim K
    Beautiful colour Rob, it will be fantastic to see it on the road.
