365GTC/4 Ignition boxes | FerrariChat
Discussion in 'Technical Q&A' started by geffen365gtc/4, Jun 28, 2007.
  1. geffen365gtc/4
    geffen365gtc/4 Karting
    Mar 12, 2005
    191
    Evening All- I'm soon to be upgrading my stock boxes ( Mark Ten B ) to a Permatune setup ( AEC 103A ).....and I have a couple of questions. The oem boxes have five wires, as follows;
    Black- ground
    Red- 12+ hot
    White- coil +
    Grey- coil -
    Green- post on the side of the dizzy
    The red wire plugs into a harness in the front of the engine bay.....I assume that this is the 12+ feed to the system. Also, what plug gaps work well with the AEC 103A???
    Thanks for the input....Geffen
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    What plugs are you going to use?
    The Dino guys have several threads about plugs and Permatunes (great unit!), but your car may be a different application,
    hope these are helpful:
    http://www.ferrarichat.com/forum/showthread.php?t=99252&highlight=plug+gap
    http://www.ferrarichat.com/forum/showthread.php?t=146707
