These are mostly Southwest planes, doesn't SW have a heavy cycle (many landings/takeoffs per 1000 hours - shorter flights)? They seem to be concentrating on the crowns ("roofs" - to some) of the body. Just heard this: -------------------------------------------------------------------------------------------------------------------------------------------------------------------- WASHINGTON -- The Federal Aviation Administration is ordering $5 million in new inspections for Boeing 737s in response to a hole larger than a football that was torn in the roof of an aging Southwest Airlines plane during a flight in July 2009. The order, which will be published Wednesday in the Federal Register, calls for repetitive inspections for cracking in the top of the fuselage of 109 planes in the 300, 400 and 500 series. Most of these models are flown by Southwest in the U.S. The more-thorough inspections for those planes are projected to cost up to a total of $5.2 million, and additional repairs could cost $17,765 per plane, according to the FAA. In a statement Monday, the FAA says the agency "always evaluates the effectiveness of our safety improvements." The latest directive is "to reduce risk further and assure continued safe operation," the agency says. The FAA reported no incidents involving the same fixtures since 2009 and the manufacturer, Boeing Co., completed hundreds of inspections worldwide "with few findings," according to a company spokesman. "This is part of the long-standing process through which airplane manufacturers, operators and regulators work together to continue the safety of the world's jetliners at the highest levels," says Miles Kotay, a Boeing spokesman. The directive is the third of four that FAA is developing in response to the 2009 incident involving Southwest flight 2294 from Nashville to Baltimore, which made an emergency landing in Charleston, W.Va. This incident was similar to Southwest flight 812 from Phoenix to Sacramento that made an emergency landing in Yuma, Ariz., in April 2011 after a 5-foot hole opened in the roof of that plane. However, the 2009 incident involved a different kind of joint than the one involved in the skin peeling back in the 2011 incident. Both Southwest flights landed without serious injuries. But safety inspectors take the problem seriously because crewmembers and passengers can be sucked out of planes, which are pressurized like balloons in flight, if they decompress suddenly. "With frequent pressurization with the aircraft going up and down in cycles, eventually there will be some fatigue that will set in," says Kevin Hiatt, president of the Flight Safety Foundation. "That's why they're taking extra precautions to take a look at this again." In the Charleston incident, a triangular hole measuring 17.4 inches by 11.5 inches by 8.6 inches opened in the top of the plane near the tail, according to the investigation by the National Transportation Safety Board. The 737-300 had been through more than 42,000 flights at that point. Passengers were startled by a loud bang and could see through the hole that opened in the ceiling at 34,000 feet. Air masks dropped for people to breathe before the pilot landed quickly. FAA says the latest order was prompted by additional reports of cracking in joints around the crowns of planes. The goal is to "detect and correct fatigue-cracking of the fuselage skin, which could cause the fuselage skin to fracture and fail, and result in rapid decompression of the airplane." The order calls for one of several types of microscopic inspections of the planes, in an effort to find flaws without actually taking the planes apart. The directive also calls for repetitive inspections of loose fasteners, with replacements as necessary. And the order also calls for installation of straps that reinforce sections of the fuselage skin. "Airplanes are very, very well engineered," says Hiatt of the Flight Safety Foundation. "Fortunately, we have a process in place with air worthiness directives where we can head off problems before they begin."
Sounds like a revision to an earlier AD. Probably reduced the inspection interval and possibly added new inspection methods. Not a big deal other than screwing up their established maintenance schedule.
Jim, I think that this is a case of plain ol' fatigue from a bunch of cycles. The Aloha problem was a case of salt water corrosion that went unchecked for too long even though it had become visible. I recall that in the design of the 727 they were concerned about the high cycle operations that could be experienced in that airplane. Now the 737 has far exceeded anything that the 727 would have experienced and is showing it. One thing to keep in mind is that the tear stopper design of the 737 fuselage structure contained the failure and localized it. I don't see a fatal problem here, more of a nuisance that rattles the public.
I read about a new theory about Aloha 243. This one claims that the original hole in the fuselage caused by the fatigue or corrosion was small and relatively contained, but when the unfortunate flight attendant was initially sucked out by the decompression, she was not pulled completely out of the airplane and, in fact, plugged up the hole, thus not allowing the pressure to fully equalize. That is what led to the subsequent larger failure of the crown of the fuselage. I'm not sure I buy that story, but it is a possibility to consider. But the fact that the aircraft still landed safely after all of that is a testament to the basic structural integrity of the 737.
The entire belly of the 43 section had been re-skinned on that airplane prior to the failure of the upper lobe. I have never heard or would believe that scenario of the flight attendant plugging the hole. I don't believe that kind of failure would start with a hole but with a panel seam letting go and the panel(s) blowing out. No way of knowing what the pressure delta in the cabin was but I'll bet that it was high enough to be explosive.
At full diff, I believe that would be 8 pounds per square inch on a 737. If the flight attendant occupied more than 25 square inches laterally, I would be surprised. That would only be about 200 pounds of force-- at the hole itself. That simply isn't enough suction to pull someone into a hole. Mythbusters demonstrated this years ago.
I think that if my memory is correct the structural max pressure tests took the pressure up to 14 PSI. I have been near two pressure test failures and they are like bombs when they let go.
Upper limit of pressure relief valve is 8.65 psi on the 737 classics. So the high blow test would have been 13 psi (1.5*1delP). Regs (14CFR 25.365) require analysis (or testing) to 2delP (1.5*1.33delP), or 17.3 psi.
Thanks, Jim C. It's been a while since I have ben around all that. I was in a b-29 next to a B-29 undergoing a structural pressure test when the nose dome and all the glass blew out. The shrapnel did some damage to our airplane and the nose dome almost took the glass out of the control tower when it hit it. I don't think many people realize the explosive force of the air pressure in an airplane at altitude. Thanks again.
I was not working on a B-29 when the blow out occurred, it was a B-50 all of which had the same nose as a B-29. The other incident occurred inside the factory when the center section of a 707-320 exploded while being pressure tested. A faulty test bench caused that one.
