3M-ing pros and cons | FerrariChat
Discussion in 'Technical Q&A' started by Cavallino Aficionado, Nov 6, 2006.
  1. Cavallino Aficionado
    Oct 3, 2006
    2,016
    Lk. Tapps/Buckley WA
    Brian
    I've seen discusion on the how-to's of this product on this site and have had numerous friends and family have this product applied on new vehicles from the dealer. I've noticed the material seems to be soft enough to attain scratches from washing drying etc? Granted some of these folks may not be using the best materials to dry with (i.e. not microfiber or chamois) but I had my Dad over this weekend and we did some polishing to his hood of his 06 LX350 and had asounding results on his hood only to be disapponinted by all the scratches visible in the 3M. Has anyone else noticed this issue? Even last week when I was at the Seattle Auto Show they had a beautiful F430 spyder in red and its 3M was covered in scratches. Can any of this this be remedied? What about aging of the paint and fading (especially in red tones)? Maybe it's worth it for the protection the material provides. Let me know what you think as I have been wavering on whether to 3M or not.
    ciao`
    Brian
  2. grold
    grold Karting
    Aug 23, 2006
    186
    Del Mar, CA
    Kevin Grold
    A 3m installer guy told me I could polish the 3m material when it showed scratches. I tried a "cleaner" wax and it came out much better than it was before I started but not perfect. I think the detailer could probably get it even better with a polishing wheel.
    Best, Kevin.
  3. TCM
    TCM Formula Junior
    Nov 10, 2003
    552
    Tyngsborough, MA
    The 3m material is very soft. It will scratch and haze over time. You can attempt to clean it with a diluted mix of isoprope(sp) alcohol and water for the yellowness. But the actual scratches are harder to remove. I have tried polishing it with very limited success as it does not cut down and fill in the scratches like a normal clear coat. Sometimes it will even jsut haze up even more. In the end, you have to decide if it is worth more to you to have scratches in the car or chips in the hood. You can always get the bra replaced as well. Hope this helps.
  4. Cavallino Aficionado
    Oct 3, 2006
    2,016
    Brian
    I think I'll try giving Griot's a call and see if they have anything they reccomend or are developing.
  5. Gerry328
    Gerry328 F1 Rookie
    2,510
    Home
    Gerry
    My '87 328 came with the treatment on the front and leading edges. The previous owner had the dealer cooridnate the application.
    I was mixed about the treatment, but in the short time I have owned the car it is growing on me. There has been more than one time that it has prevented what would have been a big chip.
    I am using 3M's "Perfect-It Show Car Liquid Wax" which they recommend for using over the treatment. It has done a great job.
    Gerry
  6. f355spider
    f355spider F1 World Champ
    18,054
    Brian,
    Your best bet is to call Accutint in Bellevue, WA they are the ones that did my buddy's F430 spider that you saw. They also did my front bumper as well. They could advise you on what methods are best to remove the fine scratches. Let us know what they say...personally, I have not worried much about it...though I do keep the painted portions well polished and waxed... ;)
    Accutint Bellevue (425) 213-1060
  7. Cavallino Aficionado
    Oct 3, 2006
    2,016
    Brian
    Thanks Hugh...
    I'll try giving them a call. I suppose a call to 3M would be worth while too.
  8. Paintshield
    Paintshield Formula Junior
    Dec 23, 2004
    372
    Grantham UK
    Tom Wakeford
    Hate to correct you but where you are going wrong is with diluting the ISO, you need to use the stuff neat on the surface of the film , I have seen this take out even cat scratches if done correctly :)
    You use kithcen towel saturated in the stuff, then add some more to get a pool then guide it around gently on the surface, make sure you mop up any run off from the edges (very important) remove the kitchen towel let it evaporate (go make a cup of coffee) after twenty minutes come back and buff with a lint free cloth , job done!
    This is the ONLY film this works with if you try this with Avey or Venture it will NOT work and will cause the effects that you describe.
    Cheers
  9. Gerry328
    Gerry328 F1 Rookie
    2,510
    Home
    Gerry
    I have had success using the 3M Show Wax, but another option is a product called Janvil Scratch Remover. There is a product system for glass and another for plastic. While I have not had to try it on my 328, I have used both products with success. The plastic product works great on scratches in clear coats.
    Gerry
