430 - 3rd Gear Dropping to Neutral | FerrariChat
430 3rd Gear Dropping to Neutral
Discussion in '360/430' started by Doocho, Jul 3, 2022.
  1. Doocho
    Doocho Rookie
    Jul 3, 2022
    6
    Kirkwood, Missouri
    A.C. Marchionne
    Hi, All. New to the F430 ownership and I have a 2007 coupe. I was wondering if someone can help me? No history on the car and finding out that the car will not upshift or downshift into 3rd gear and instead shifts to neutral. I have to upshift to get it back in gear and usually starts at 6th and I downshift from there. Happens after the car warms up and in auto or manual. Outside of that, the car shifts very well in all other gears with no slippage. No strange noises or leaks that I can see. Just doesn't like 3rd gear. The car seems to have been kept very well. Does anyone have a short list of things I can check before I head to the dealership? I am very mechanical and have worked a lot on a lot of foreign cars in the past. I have also disconnected the battery for 20 minutes, touched the cables and did what I thought was an ECU reset. No service lights on, either. Thanks for your help!
    Photos of the car and engine to provide context on the level of care from the previous owner.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,896
    Central NJ
    Dominick
    #2 flash32, Jul 3, 2022
    The two probable causes are a lost of pressure or bad sensors
    I would invest in a dongle to read codes ( even if light is not on and see what is stored) -
    https://www.amazon.com/Autel-AP200-Bluetooth-Professional-Automotive/dp/B07QD4GZW4/ref=sr_1_1_sspa?keywords=autel+ap200&qid=1656884157&sr=8-1-spons&psc=1&smid=A2AABGNVYH57FL&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFGTkdNSVBQWkNUOTEmZW5jcnlwdGVkSWQ9QTA1OTk3NDAxTTJCSUpVSjVJWjE0JmVuY3J5cHRlZEFkSWQ9QTA0NTMyODQzN0wwME9HWkI4OVlBJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
    Also .. check timings of f1 pump cycles ( how long it stays on , how long does it stay off ) for both key "on" and the with Engine "on"
    Also see how many shifts n to 1 to r to 1 etc do you get before you hear pump .. do multiple times
    Use stopwatch
    How many miles .. any clutch changes ?
  3. Doocho
    Doocho Rookie
    Jul 3, 2022
    6
    Kirkwood, Missouri
    A.C. Marchionne
    So here are some answers:
    Door Opening: 3.81 Seconds
    Key: 7.65
    Gear Shifts: The gear shifts from N to R and R to 1 and 1 to N seem pretty good/quick. Pump comes on for a ~3.8 seconds from N to 1.
    Mileage is 43,100
    And will the Autel allow things like measuring clutch life and bleeding the transmission? Or is it better to buy the Launch 431?
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,896
    Central NJ
    Dominick
    How many shifts did it take to start pump
    How long does pump stay off with key "on" and while idling
    The ap200 is a lifetime read only tool .. will give you info on clutch but will not be able to do any functions
    The next step would be a thinkdiag with is a yearly per car subscription and pretty much uses similar software as the launch x431
  5. Doocho
    Doocho Rookie
    Jul 3, 2022
    6
    Kirkwood, Missouri
    A.C. Marchionne
    So the pump stays off for 14 minutes and 25 seconds before turning back on with the engine off. I waited 16 minutes and 32 seconds with it idling and couldn't hear it so I think I may have missed it. Nor could I hear the pump shifting when I was inside the car with the engine on and changing gears. The car is super loud with no muffler.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,896
    Central NJ
    Dominick
    Let's talk again when you get the tool
  7. Doocho
    Doocho Rookie
    Jul 3, 2022
    6
    Kirkwood, Missouri
    A.C. Marchionne
    OK so @flash32 has been so helpful and if you are following this thread, here is where we are right now:
    1. Purchased the ThinkDiag software which is the equivalent (and way less expensive) to the Launch 431 software. Absolutely love this product.
    2. We have determined the clutch wear is at 39% (61% remaining).
    3. F1 pump timing is a little borderline but passes specs.
    4. Identified a P1770 code for gear engagements with wrong shifts.
    5. We ran a relearn on the clutch and still awaiting a test drive.
    6. Potential next steps include changing the accumulator and doing a full bleed, followed by clutch position sensor replacement and regulator valve replacement if needed.
    Codes have all been cleared and heading out for a drive to see if anything has changed with the clutch relearn. Also running real time diagnostic reports during the drive.
    Updating later....
    VAF84 likes this.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,896
    Central NJ
    Dominick
    Thanks for the kind words ..Been a pleasure helping you
    One correction in the plan step 6
    Not a position sensor but the F1 potentiometer sensors
    tbakowsky likes this.
  9. Doocho
    Doocho Rookie
    Jul 3, 2022
    6
    Kirkwood, Missouri
    A.C. Marchionne
    @flash32 is really amazing. Thanks for all of your help walking me through the troubleshooting and it looks like my car is shifting perfectly now. Still going to change the accumulator, though, after driving for another 1-2 weeks. But the relearn and all of the diagnostics show my car is in good health and working properly for right now.
    Could not have gotten this far without your help!!
    AandSC and flash32 like this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,896
    Central NJ
    Dominick
    My pleasure....love to help and hopefully share some knowledge
    If we fixed it...great!!... If not, we still have a plan
    Now that it is running properly..go enjoy
    AandSC likes this.
  11. Gio88
    Gio88 Rookie
    Jul 10, 2022
    10
    Italy
    Giorgio
    Hello,
    I'm Giorgio, from Italy, yesterday on my F430 I got exactly the same Doocho's problem. Could you give me the sensor part number please?
    Is the part 248095 or 219340?
    Thanks a lot
