3rd Party 355 exhaust bypass valve | Page 2 | FerrariChat
Discussion in '348/355' started by tonyyoshi, Feb 22, 2005.
  1. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Do any of you know the technical differences of the 355 and the F50 bypass valve? Why would the F50 BPV work better/last longer than the 355 BPV?
  2. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Ferrari Engineering Department figured out what a crappy design the 355 was and changed it going forward I know its a radical concept but could be?
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    I did that to mine this weekend, it sounds great!!
  4. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Making a vacuum bypass sound better than using a wire. Any way to control the vacuum while driving. It sounds as if it would be possible to manually control the solenoid valve. Would be great to manually select setting. I Really like the option of driving home late at night without disturbing all the neighbors :)
  5. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Guess a ball valve with a purge button would work!!! I will look for one.
  6. F355 SCOTLAND
    F355 SCOTLAND Karting
    Apr 20, 2006
    126
    Dumbarton
    mark reilly
    check the solenoid is working before going to any expense, it operates the valve, if you lie down at the back of your car its at the bottom right hand side near the exhaust tail pipes look undneath and you will find a black and a blue multi plug each one is attached to a small plastic cylinder shaped solenoid, the terminals are prone to corrosion, pop them off and spray with wd40 and try again. hope this helps, i was the same mate i was gutted at the prospect of shelling out big bucks for a new diaphram or valve and it cost me £2.00 for a can of wd40 and it cured my problem!!!! good luck
  7. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    If you find a ball valve that works, please write back.
