3x8 Audio: Blaupunkt Bremen SQR 46 DAB | Page 2 | FerrariChat
Discussion in '308/328' started by Brian A, Feb 25, 2022.
  1. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Grabbed a flashlight and went into the car in the total dark. First song: "Junior Wells performing Tracy Chapman's "Give Me One Reason." Wow.
    Raised the buckets with the headlights off. Adjusted color to match the gauges. R=3, G=3, B=6. What have others settled upon?
    Adjusted dimness to match the gauges. Set brightness = 1. Still brighter than the gauges. I need LEDs.
  2. judd10
    judd10 Formula Junior
    477
    Seattle, WA
    Great find and thanks for the heads up around purchasing on Amazon.de. To complete the upgrade, any recommendations on speakers? I have an '85 QV. Does anyone happen to know what the diameter of the OEM speakers are? I imagine I'd have to get shallow mount speakers.
  3. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    1983 US 308 GTS QV
    The factory speakers are quite small and don't produce great sound. I don't remember the factory size. If you phone Crutchfield, they would probably know.
    The problem is not so much a speaker magnet depth problem as it is a speaker grille problem. There is no clearance for bigger speakers and the factory grilles are not sonically transparent. Higher frequencies, actually anything above the higher mid-range, will struggle.
    There are lots of speaker options for great sound, although this is not a car you want to get too fanatical about since engine and road noise are too high to have any sort of high fidelity experience. Any stereo equipment outlet, such as Crutchfield, can give you good advice. A common solution has been to cut out the factory speaker grilles, install big speakers and cover the hole with a metal speaker grille. Going one step further, it is common to install matched tweeters in the manual emergency window door crank holes.
    If your car is a concours level car, as is mine, you have to be careful not to go too crazy on appearance. The concours judging rules allow for something to the effect of, "tastefully installed stereo systems". Rifledriver says that my leather non-factory speaker grilles should be a deduction, but I have never been deducted for them. I also have tweeters in my window crank holes and a small power amp mounted behind the carpet on the driver's front bulkhead. (Before anyone titch, titches me about this placement of the amp, there is so much room ahead of the pedals, the amp cannot possibly impede their travel, I've anchored the amp such that it cannot come loose and the amp has a thermal cut-off should air circulation behind the carpet somehow get blocked.)
    Sitting quietly in the garage, my system sounds pretty darned good. ... today, I take it out for its first drive with the new stereo system. I don't have high expectations.
  4. judd10
    477
    Seattle, WA
    Thanks for the info. I called crutchfield and they didn’t have the 308 speaker size. I’m guessing they are either 5.25” or 6.5”. Do you have a pic of your tweeters in the window crank holes?
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    They're 5.25", and I personally know that a depth of at least 1.9" will fit.
  6. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    1983 US 308 GTS QV
    As planned, I took the car out, roof off, windows down, microphone in hand and phoned my wife while at speed. She gave me feedback as to which microphone location gave her the best sound of my voice. Surprisingly, it was not the upper corner of the A-pillar where the old microphone was but rather down beside the ignition key. When I got back to the garage, I mounted it on the other side of steering wheel, at the corner shelf, which gave her equal sound quality.
    While out on the road, I also cranked up the volume to listen to music over the din of the engine. It was very good. I don't think I caused any hearing damage.
    About the only surprise is that the "day" setting for display brightness is too dim. I've got it set on the maximum brightness (brightness = 16). I am hoping I am missing something in the instructions.
    This project is now fully done.
    You may find threads like this useful:
    1985 308 QV Door Speakers & Tweeters
  7. judd10
    477
    Seattle, WA
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,843
    Mike 996
    Good Luck; be sure to let us know how they fit!
    judd10 likes this.
  9. Rilez
    Rilez Karting
    Jun 24, 2020
    159
    Los Angeles
    RILEY
    Was looking at these as well… look forward to your review as well.
  10. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    1983 US 308 GTS QV
    I've fixed the daytime brightness issue. Although the overall brightness can be adjusted with a general "brightness" control, brightness is also impacted by how high each of red, green and blue colors are independently set. The 308 lighting is a bluish color. Instead of starting at r=0, g=0, b=0 and working upward, I cranked all three up to their maximum brightness values of 16 and reduced green and red until the Bremen color matched the instruments. I ended at Red = 10, Green = 13 and Blue = 16. Much brighter.
    I must say now that I believed a fallacy that a 308 could not have high audio sound quality. It has to be louder, but my stereo sounds great over the sound of the engine and wind noise. On long stretches of plain highway, I may now play my Bremen.
    An operational surprise was that the phone goes through the unit even when the unit is turned off (although ignition must be on). Said another way, while driving the car with the Bremen switched off and my iPhone sitting on the passenger's seat, an incoming phone call will wake the Bremen and route the call through the car's audio system.
    mike996 and kiwiokie like this.
  11. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
    Post more pics please.
  12. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    1983 US 308 GTS QV
    Humm, (Not sure what it is you want to see) ...
    Here is a photo of the installed unit. It looks better in person than in a photo. The dangling wire is the microphone wire, which I hadn't installed yet when I took the picture.
    Here is a photo of my infamous (non-factory) speaker grilles and my tweeters (Infinity speakers). Modern speakers can make huge base without a subwoofer. Also note the microphone placement between my nifty outdoor thermometer (sender in front grille of car) and USB ports/Volt meter.
    This last photo is of the wiring under the dash. It still looks like a mess, but I consider it quite tidy (you should have seen it before). The black plastic split wire loom tubing holds the antenna wire, 12v trigger wires and the line-level interconnects between the Bremen and my power amp (which you see behind the clutch and brake pedals). The other colorful twisted cable running beside it is a 4-wire 16-gauge cable which returns amplified signal from the power amp to the factory wiring running to the speakers in the doors. The phone jack is for the telephone microphone which was not hooked up yet. The dangling USB pigtail is the rear USB port, which I later wire-tied underneath the dash (I now have a USB flash memory drive plugged in with lots of mp3 files). The enormous red wire against the bulkhead is an unswitched 12v power supply coming directly from the battery a stereo installer put in once-upon-a-time. Since it is there, I use it for my power amp power supply. It's on its own in-line fuse.
    NoGoSlow and RodC328gts like this.
  13. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I never would have thought about putting an amp there.
  14. Dr Tommy Cosgrove
    36,301
    Birmingham, AL
    Tommy
  15. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    1983 US 308 GTS QV
    Per my prior post …
  16. ValentinoQV
    ValentinoQV Karting
    Jun 29, 2016
    51
    Westlake Village, CA
    Lindsay Vannoy
    I decided to go with the Bremen SQR 46 as well for my 1985 QV GTS. It seems the door recess was originally designed for a 5.25" speaker. I wanted to use a set of 6.5" speakers to get a better bass response but the outer mounting rim would need to be trimmed down to fit the stock door recess, which I was willing to do. I went with a set of Focal Access 165 speakers but the basket was too broad to allow them to sit flush. After much searching I found a set of JL Audio C2 600X speakers which have a 6" diameter. The tweeters are adjustable and still allowed me to use the original speaker grill.
    Brian A likes this.
  17. ValentinoQV
    ValentinoQV Karting
    Jun 29, 2016
    51
    Lindsay Vannoy
    For those interested, here are the specs for the speakers.
    • 6" 2-Way Car Audio Coaxial Speaker System
    • 0.75" Silk dome tweeters
    • Mineral-filled polypropylene cones
    • Stamped steel frames
    • 60W RMS
    • 225W Peak
    • 4 Ohm
    • System Efficiency: 90.5dB
    • Frequency Response: 59 Hz - 22 KHz
    • Mounting Depth: 2.38"
    Brian A likes this.
  18. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,843
    Mike 996
    Just to clarify - those speakers mounted in the original location with no modification required of the sheet metal or the original cover?
  19. ValentinoQV
    ValentinoQV Karting
    Jun 29, 2016
    51
    Lindsay Vannoy
    That’s correct, no modifications. I don’t remember if the mounting holes lined up but easy enough to redrill the speaker basket.
  20. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,136
    1983 US 308 GTS QV
  21. wfu97
    wfu97 Karting
    Jul 15, 2018
    101
    North Carolina USA
    Scott
    That is a good price. I think I paid $500 for mine a few years ago. Also on the speakers, I installed 6" Audiofrog speakers from Crutchfield. The holes did not line up exactly, but very little modification to the speakers and they fit in the original holes with the original speaker covers.
  22. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,592
    Argent/Brasil
    Guido
    I was thinking to put this Blaupunkt Bremen also in my 328. But hat the oportunity to buy a period correct radio/cassette in good shape = Alpine.
    All is working like it should and I have a lot of cassettes with the correct music.
    speedcat, thorn, RodC328gts and 2 others like this.
  23. Joholden1
    Joholden1 Rookie
    Dec 14, 2022
    7
    James P Holden
    I’m thinking I might just listen to V12 for a year then figure it out. Thanks all. Would love blue tooth and Sirius but not at the expense of original look.
  24. RodC328gts
    Aug 17, 2021
    458
    Mexico
    Rod C
    You have a v12 on a 3x8?
    iMHO the looks of this stereo is very period correct.
  25. wildrnesxperienc
    Apr 9, 2022
    193
    Los Angeles, CA
    My 90’s Pioneer tape deck in my 86 328 crapped out on me the other day. Radio works but the cassette player makes a horrible noise and doesn’t play. Ate a tape too. I’m looking at this Blaupunkt but I’m curious- has anyone with this one installed had their car concours judged? My car was a Platinum car about 5 years ago with the PO. I want to maintain that award.
