4 hole injector upgrade and more | FerrariChat
Discussion in '348/355' started by Aceofspades, Jun 25, 2019.
  1. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
    So since I have my motor down for timing belt service and have been looking into the 4 hole injector upgrade is there any thing I should be looking out for with injectors?
    Also any thing else I should be upgrading ?
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I have seen several threads out here about those seemed they caused issues. Run some searches and read before you buy.
  3. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
    Not seeing a lot of info besides one long debate.
    And most people claim it helped the car
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    The ECU tunes back the fuel rate so no real advantage unless your OEM are clogged
    4 holes will have more volume less pressure and not as good a spray pattern, you would need to bump your fuel pressure up and dial in the ECU more aggressively.
    I run OEM on the street with one of the higher HP 348s with great gas mileage
  6. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,180
    Atlanta, GA
    Steve D.
    Not if they're the same flow rate as stock. if they're the same flow rate the holes are much smaller in the 4-hole and the atomization should be better.
    sjd
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    The 4 holes have a higher flow rate then the 2
    I must have 10 sets all sizes to play with plus a close friend owns RCrcuelinjection that gives me access to all the cool test equipment
    bosch 2 hole is more then sufficient up to 320 rear hub HP on dyno tests
    steved033 likes this.
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I assumed the 4 hole non Bosch ones were not scientific in that it's probably the same size holes as oem or a guess size so it would just dump fuel and run less than opimal. I am very skeptical on those myself.
    Sent from my LM-Q710(FGN) using FerrariChat.com mobile app
  9. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
    The set I am looking at are bosch 21IBs @ 43.5 psi
    4 hole VS the 1 Hole stock injectors in my 90
    at 145 dollars shipped its not a bad price
    But what are the draw backs .....
    I still plan to send my Stock units to RC for cleaning
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,794
    Lake Villa IL
    Cheap injectors are usually junk. So, besides not having the exact same flow characteristics as an original injector they could have poor balance or leak.
    I would never personally run anything but an original injector on these cars unless you are changing the engine management as well. Even at that point, would not use the injectors you mention based on price alone.
  11. boxcarracer
    boxcarracer Formula Junior
    Jul 29, 2005
    333
    Montreal
    Luigi
    The best thing to do IMO is just rebuild your stock injectors.
  12. Lavenknight
    Lavenknight Karting
    Jun 2, 2018
    79
    Chicago, Illinois
    Alberto
