4 point omp hardness installation testarossa | FerrariChat
Discussion in 'Technical Q&A' started by jamesrobba, Jan 31, 2007.
  1. jamesrobba
    jamesrobba Karting
    Dec 5, 2005
    211
    north downey, calif.
    james joseph robba
    need help , installing 4 point omp red hardness in my 87 testarossa , want a clean installation , can anyone help on the proper hook up to install upper belts and lower belts please, reguards to all my ferrari friends
  2. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,209
    socal
    Stick with proven oem for the street. On the track consider using a 6pt parachute styel if you are using stock seats. 4 pts are not adequate unless you are using a schroth style ASM system
  3. Nuvolari
    Nuvolari F1 Veteran Owner Silver Subscribed
    Sep 3, 2002
    6,651
    Toronto / SoCal
    Rob C.
    Unless you are planning on putting in a roll cage, leave the stock 3 point harnesses in. With the 4 point you will snap your neck in the event of a roll over (it is much easier to happen than you think).
