400GT V12 rebuild | FerrariChat
400GT V12 rebuild
Discussion in '365 GT4 2+2/400/412' started by Flinch, Feb 7, 2010.
  1. Flinch
    Flinch Formula Junior
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    Hi guys!
    Thought I'd share my rebuild with you all. I have been working on it for a few months now. The engine has been apart for about 10 years and I bought it last year as a project. Het car has been restored in the past, but the engine shredded 2 pistons just after the first few hundred miles. The previous owner had recorded the engine strip so I had some idea of what happened. Now I am almost done, but small stuff remains, like ignition timing, testing and other loose ends. My goal is to have it running this spring
    Want to see pics? I threw it all in a youtube-clip => http://www.youtube.com/user/zwedenhuizen#p/u/7/l3Jd5uVQpsk
  2. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Peter.. Thank you sooo much for sharing your labor of love with us all. I'm quite certain that you are going to be receiving many compliments on your fine work. Jacques.
  3. koisokok
    koisokok F1 World Champ Rossa Subscribed
    Dec 8, 2006
    12,302
    nine 0 two one 0
    its going to be a great spring time for someone!!! THXS FOR SHARING, :)
  4. 350HPMondial
    350HPMondial F1 Veteran Silver Subscribed
    Feb 1, 2002
    5,325
    Edwardo
    Love the carbs.. and the Tail-lights.
    Nice Video, great song.
    Grazzi,
    Edwardo
  5. alastairhouston
    alastairhouston Formula Junior
    Apr 19, 2009
    575
    Largs Scotland UK
    Alastair Houston
  6. Fritz Ficke
    Fritz Ficke Formula 3 Rossa Subscribed
    Jan 3, 2006
    2,266
    Tucson, AZ.
    Fritz Ficke
    Thanks great video.
  7. Ashman
    Ashman Three Time F1 World Champ Owner Silver Subscribed
    Sep 5, 2002
    33,266
    MA
    Great pictures, thanks for sharing!
  8. Rifledriver
    37,105
    That piston and rod were a mess. How did that happen? Any idea?
  9. Flinch
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    I think too many cold starts and high revving while cold, without leaving a showroom! The excessive gasoline desolved the oil between the piston and liner. One piston seized up, an other one cracked at the side and in total 4 liners had vertical groves. No to other damages where found, so I guess that should be the only reason.
  10. Ashman
    Sep 5, 2002
    33,266
    MA
    Without leaving a showroom? That is an incredible amount of damage with no load on the engine even with a cold start, thick oil and a rich fuel mixture washing down the walls of the piston bores! They must have revved the piss out of that engine while cold over numerous cold starts. I would not have thought that could happen, but then again, I never would treat a cold engine that way either. That borders on criminal abuse of an engine!
    The good thing is that you will have a fully rebuilt engine and can treat it right from the beginning. You must be pretty excited at the thought of being on the road in only a few short months!
  11. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,465
    Canada
    Newman
    Defective part or machined incorrectly, cant do that running up a cold engine in a showroom and the fact it was just rebuilt says someone most likely screwed up. We have an idiot lotboy here at the dealer that mats brand new cars right off the truck and ive never had to replace an engine in one of them yet.
  12. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Agreed. I'd perhaps attribute spun bearings to cold revving but a bent rod?
    Regardless of cause glad you saved it.
    Did I see a '66 Barracuda in your garage also?
  13. Flinch
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    Yup, l own some fun cars. Love the '66!
    About the con rod : The piston cracked and got stuck in the liner at an about 20 degree angle . The conrod was still pushing upwards and ripped the pin and what was left of the piston (thankfully the piston stayed in the liner and did not get smashed into the head)
    Other liners had serious grooves showing a lack of lubrication. All other parts (cams, bearings, heads and crank were okay. I have seen this before in racing engines with low weight pistons, but I can not call the 400 pistons lightweight. Oh well, **** happened and the engine has a new career ahead. And I will treat it nice ;-)
  14. Fritz Ficke
    Jan 3, 2006
    2,266
    Tucson, AZ.
    Fritz Ficke
    Flinch, Thanks for sharing, please keep us up to date on your progress.
    On the con. rod with a carb. engine I can imagine people pumping the pedal to start it and washing the oil off the cyl. walls easily, and I wonder if enough gas can be pumped in by a over zelous/naive operator to hydrostate, enough to bend rod? or maybe a stuck/gummy float?
  15. brettski
    brettski Formula 3
    Feb 29, 2004
    1,754
    north of toronto
    brett swaykoski
    nice video...all the best with the project.
    i found it very interesting that you installed the motor with the tranny bolted on...wow.
    i've only ever seen that done on domestics before.
    i noticed you had a cool boom to help... but i still can't imagine it's easier that way...
    that tranny is so easy to remove and install from underneath...very interesting though.
    i'm sure you had your reasons and i would be interested to here them.
    as for the bent rod, it could have been a few different things, or a combination of things.
    we fired a 365 motor yesterday that we just rebuilt...and it came to us with a bent rod.
    it had also had other similar damage as your motor...tough to tell what happened first.
    brett
  16. Flinch
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    The bent con rod will be a mystery for me as I did not take the V12 apart myself. I just had to put up with the story the previous owner told me. He owns a landrover workshop, so he has some experience fixing cars ;) But is still remains a story. My first thought too was that the piston ran into a large volume of somekind of fluid. But that still does not explain the cracked sleeve on anoter piston and some deep groves in some liners
    We scooped the engine and tranny in because of logistic and time issues. My buddy owns a very busy restoration shop and we just had one weekend to get the drivetrain in before his project arrived. And as he makes his money that way... We pushed the 400 to the neighbor becaus of the kinda large crane he has. We put the body on 20inch blocks and the complete drivetrain went in very smoothly. I think 30/35 minutes, with a 3 man crew (two always carring a beer, so they were not very busy). You will need some hours to get them in separately, so we went for our option
    btw : here is pic of the ruined piston
  17. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,386
    Houston, Texas
    Bubba
    That is sure a beautiful car you have, because of this misfortune, it really looks in great condition!
    Enjoy!!!!
  18. Flinch
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    And it still is a perfect car, really like new! Here is a pic of my 400 from about 10 years ago when it featured in a dutch high-end car magazine
  19. BigTex
    Dec 6, 2002
    79,386
    Houston, Texas
    Bubba
    Never had seen it side by side to the Boxer before, to note the front glass, it
    could be the same part!
    That's a huge piece of glass, by the standards of the day.......
  20. jsa330
    jsa330 F1 World Champ Silver Subscribed
    Oct 31, 2003
    10,046
    75225
    Scott
    Great video of fine work! Wish I could do that.
