400i AC help | FerrariChat
400i AC help
Discussion in '365 GT4 2+2/400/412' started by relostrat1, May 23, 2008.
  1. relostrat1
    relostrat1 Karting
    Apr 9, 2008
    50
    Cincinnati
    Tim Haines
    Hey all,
    I have looked through archives but couldent find a solution.
    The 400i is now running smoothly after new plugs, some tinkering and the replacement of a couple of fuel lines that were loosing pressure.
    The mechanic today was exploring the AC problem. He says nothing happens when he turns the system on. The system seems charged, but the compressor and such do not activate once turned on.
    He has asked for a wiring diagram? Is there one online somewhere?
    Any suggestions as to where he should start?
    Much thanks.....
    Tim
  2. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    Tim,
    1) The compressor will not come on if the radiator fan isn't working. So first make sure it is up to snuff. It should turn on the instant you turn on the yellow a/c fan knob.
    2) The high and low pressure switches are prone to going bad. If they are gone you'll get no compressor action. Tell your tech to bypass BOTH of them and see if it kicks on. If you need a new one I have an extra I bought that I'd like to get rid of.
    Assuming the system really is charged and its not something stupid like a fuse (which I assume you've checked) I'll bet one of the two above solves your problem.
  3. Steve Magnusson
    26,764
    #3 Steve Magnusson, May 23, 2008
    Download the 400i OM (the one published in 1979 for your 1981) from www.ferrariowners.com -- the schematic is in the back.
  4. relostrat1
    relostrat1 Karting
    Apr 9, 2008
    50
    Cincinnati
    Tim Haines
    Dave, thanks as always. I have passed our information on.
    Steve, I assume I needs password to get to that site, I will try it out.
    Thanks.....will let you know.
  5. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    My pleasure Tim. Let us know how it goes.
  6. b3tech
    b3tech Karting
    Apr 17, 2007
    100
    Los Gatos CA
    Boyd Bowdish
    I have a question, is the 400 A/C system R-12 based? If so, I use a non-CFC product called Freeze 12 as an R-12 replacement. Goto e-bay and search freeze 12. It works very well.
  7. Steve Magnusson
    26,764
    Yes, you'll need to get registered (which can be a hassle), but it's worth it IMO. Also, you should get a hardcopy of your OM anyway -- they aren't that expensive and are completely liquid IME.
  8. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Tim
    I have the dual AC system so I knew my compressor et al was in working order. However, my rear system stopped functioning. The fan would come on but the compressor would not engage. It was a faulty switch/relay (yes two for the high price of one). Switches are available. You can test by jumping one of the wires that powers the compressor. Switch has 5 prongs as I remember correctly: Power in, Power to compressor relay, Fan Low, Fan Med, Fan High. Power to compressor should be on in all three fan positions. If your fan comes on check for the three hot terminals and jump and see if one never gets hot (literally hot is what makes the switch fail).
    Ken
