400i and 2 alternators | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by YorkieV12, Jun 12, 2017.
  1. YorkieV12
    YorkieV12 Karting
    May 23, 2014
    132
    Just stripping out the engine bay for engine and autobox removal....and find that the mounting bolt on the lower alternator is seized solid into the alt. body. Leave it alone until the engine is out......but one hell of a problem if the car was only in for a service. So, when it all goes back together Plan A will be to fit a single high output alternator instead of the upper 55amp. Not worried about 'originality' when a future problem can be eliminated. I don't see any problem with this 'fix'..........surely someone has been there and done it already ? ? Yes ?
  2. Steve Magnusson
    26,764
    #2 Steve Magnusson, Jun 12, 2017
    It may not be as simple as just replacing the stock 55A upper alternator with a higher amperage alternator as the stock V-belt system (using the smallish Gates 7M V-belt) doesn't have a lot of design margin (as proven during the 308 to 308i evolution) -- however, it was the correct original design choice because using bigger alternator V-belts would just increase the HP loss. If it was a situation of going from 55A to 65A, I'd go with "probably OK", but I wouldn't be hopeful that you could go from 55A to 110A. JMO.
    Maybe I'm wrong, and others will be able to post their experience, but please do let us know how it works out.
    Edit: Don't have access to the 400i schematic at the moment, but another factor may be the gauge of the wires going from the alternators to the battery -- if the same gauge as used on a (single alternator) TR = no problem. If significantly smaller = could be an issue.
  3. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Steve is correct. I changed the upper alternator to a larger one but it would destroy the belt on a regular basis. I went back to the old alternator but added adjustable voltage regulators that seemed to allow the units to come up to voltage at lower RPMs.
  4. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    I believe the two alternator wires combine into one just inside the hood closure on the left side in front of the air filter box (400i). I am not sure but I think the combined wire is same as each individual, why would you need heavier wire in Italy?!?!
    Ken
  5. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Ferrari engineers never really had a firm grasp of electricity until a few years ago.
  6. Steve Magnusson
    26,764
    Yes, that's a bit of an odd design decision ;) The individual wire sizes are OK for 55A alternators, but the same size for two is marginal.
    Mark -- What current level (single) alternator did you try?
  7. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I'm not sure. It was a while ago. I do remember it was from a truck. I had to build a custom bracket for it.
    I put a really small pulley on to build voltage early. That may be why it kept eating bellts.
  8. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    No good reason reason to convert to a single alternator, the dual alternator system works well, Ferrari used Bosch Alternators, they are reliable and parts are readily available to rebuild them if necessary
    The 2 alternators provide redundancy in case of a belt failure.
  9. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,447
    Canada
    Newman
    Agreed, I like having two because a back-up is handy.
  10. YorkieV12
    YorkieV12 Karting
    May 23, 2014
    132
    Thanks all, for the good advice, I'll take it. Two it is then, not wanting to re-invent the volt.!
  11. MrKazimi
    MrKazimi Karting
    Oct 7, 2014
    150
    Kuwait
    Dr. Mohammad
    Do you have the Bosch Part numbers by any chance?
  12. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    I have had on 2-3 occasions been on a long drive with AC on, with or without lights and wipers and when I stop I have a dead battery. Thee ae other posts about this but two 45 (?) Amp alternators are marginal for this car. Look at the power load: 3 fans, two fuel pumps, AC fan(s) and then add in lights and wipers and it is easy to come up close to 90 amps.
    I am contemplating finding a 60 or higher AMP alternator to replace the top one, where the small belt wrap around is nearly 270 degree. Can anyone suggest an alternator, Bosch part #?
    Ken
  13. Steve Magnusson
    26,764
    Are you sure that both alternators are working well? Can't say that there's anything wrong with your math, and the system doesn't have a lot of design margin, but has that been a widely reported problem for 400i?
    What voltage do you measure at the battery terminals under different conditions? Say:
    1. idle, no other electrics "on"
    2. ~2500 RPM, no other electrics "on"
    3. idle with AC "on", headlights "on", wipers "on"
    4. ~2500 RPM with AC "on", headlights "on", wipers "on"
    I wouldn't be totally freaked out if #3 was marginal, but if #4 isn't good = that needs help/repair IMO.
