400i brake problem... | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by jes-13, May 20, 2007.
  1. jes-13
    jes-13 Karting
    Jun 9, 2006
    56
    California
    Our 400i was dripping brake fluid off the rocker in front of the left rear tire. The fluid was dripping out the small square frame tubing behind the rocker. I searched for the source and I assumed it was coming down the firewall and finding it's way to the square frame tubing. My assumption was that the master cylinder had an internal leak that was finding it's way out through the booster... I had the M/C rebuilt, it required sleeving. What's the chance the rebuild would fail in an identical way after sleeving? The only other thing I can think of is that a brake line has rusted through, but that seems kind of extreme for a California car... :confused:
  2. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,005
    MA
    California or not, the newest 400i is 22 years old and that is a lot of time for a leak to develop, not only through corrosion, but also through abrasion or through a fitting loosening up. Put the car up on a lift and check all along the brake lines from the MC to each wheel.
    Good luck
  3. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    I have just rebuilt the brake system on my 1980 400i..If you're interested in any particulars..contact me ...sources,ect...Jacques..
