400i bucking / jerking at low load and rpm | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 71Vette, Apr 26, 2024.
  1. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Hi all,
    I've gone through the injection system on my 1982 400i manual, and all appears to be working and within spec. CO at idle is set to 2,0% with the idle at 1050rpm.
    The car idles fine and drives well under load, but has a tendency buck and jerk some at low loads and on the overrun.
    Any tips on what to be looking at?
    What I haven't checked yet is the ignition timing, but I've gapped the NGK BP7ES plugs to 0,65mm. The plugs are quite light in colour, so it certainly isn't running rich.
    The car runs on 98 octane RON fuel.
    Cheers
    Esben
  2. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Check your distributor advance. Is it sticky? Advance should increase smoothly from idle to 5000 RPM.
    Ken
    71Vette likes this.
  3. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Thanks Ken,
    That is one of the next items on my list of things to do!
  4. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    I took the cap off yesterday, and the mechanism doesn't feel very smooth. So that will need looking at.
    I also got a tip from a friend who owns a 365 GTC/4. He says the carb'ed cars run best with CO set at about 4%, so that'll be worth a try too. Obviously well out of the 1-2% range set by Ferrari, but emissions probably had a say in determining those values.
    Esben
  5. Steve Magnusson
    26,785
    That's more because carburettors just can't work well below that value ;). 2% CO is already the "standard fudge up" for K-Jet systems as the F spec is usually more like 0.8%-1.2% CO at idle on the K/KE-Jet models. If 4% CO at idle "fixes" your runability issue, you are just masking some other issue that you haven't identified yet -- JMO. Good Hunting!
    71Vette likes this.
  6. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Esben
    I had sticky advance mechanism just before a 5-day rally. We had to get home on a flat bed. In an hour or so, I got cap off and squirted some lube down inside, wiggled rotor around. It ran like a top for the 5-day rally.
    Afterward, I sent distributor to Dave North in NJ who rebuilds them. He has an ad in FCA magazine. He replaced top and bottom bearings, lower seal, and then set up weights and springs on a distributor "dyno". He gave me the advance curve results. Car ran perfectly once reinstalled and idle advance set.
    You could do my first action to see if you are on the right track.
    Ken
    71Vette likes this.
  7. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    I'm going to remove the distributor at the weekend to have a proper peek inside.
    Ist there anything particular to watch for whilst removing it?
  8. raemin
    raemin Formula 3
    Jan 16, 2007
    2,339
    Lyon (FR)
    R. Emin
    Before removing the distributor (that's a painfull task!), as suggested by ken, just remove the cap, and the rotor "finger", then check that the wick inside the hollow of main shaft is filled with oil. If it is dry just lube the wick and the spread some oil on the cams.
    Once all is thourougly lubed, you can wiggle the distributor rotor. As the main shaft will be locked by the camshaft, if you move the rotor, the only thing that will bulge will be the cams of the distributor. So you will feel the resistance of the springs while the cams are "opening". You can gently actuate the cams till they feel smooth again.
    Sorry for the so-so english. I hope you get the idea...
    71Vette likes this.
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    2,339
    Lyon (FR)
    R. Emin
    As far as adjusting the distributor, that's not such a straightforward task:
    1) aside from the poor accessibility,
    2) the distributor is located in an extreemly hot area, so the heat plays its toll on the bearing and the seals. In other words if you remove it, just replace all these.
    3) Additionnaly the shape of the distributor is not compatible with most distributor tester, so even if you find someone who has access to a Sun or Alen tester, you will need the specific adapter that allows to mount the distributor on the testing machine.
    So you'd better be sure your distributor is the culprit : test the advance with a timing light first, and check the temperature of all the exhausts (you may have a few missing cylinders).
  10. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Thanks!
    Your English is just fine!
    Are you French? I speak French too - I suppose we could annoy the rest of the forum by switching to French
    Esben
  11. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    What kind of oil should I use?
  12. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Something light like 3-in-1 oil.
    71Vette likes this.
  13. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    I did actually remove the distributor, as lubing didn't seem to do much.
    2 of the 3 nuts fixing it were actually missing, so probably not such a bad idea.
    The bearings were OK, but the advance mechanism was very gummed up. I cleaned everything, lubed the moving parts and reassembled everything.
    The mechanism now moves smoothly, but the bucking hasn't completely disappeared...
    Next is to check the advance. If I was to bet, I'd say that the ignition is too far retarded, as the distributor is turned almost as far as it will go in clockwise direction.
    Cheers
    Esben
  14. samsaprunoff
    samsaprunoff F1 Rookie
    4,456
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Esben,
    Firstly, do not mix up the springs, pins, or the very thin washers that might be present underneath the "pin" or inside the pin's cylinder. All of these items contribute to the distributor's advance curve and can be specific to each weight. Secondly, be very careful withe the plastic bushing (the advance weight rests against this bushing) that is affixed to the center shaft. This bushing has a specific outer diameter which sets the maximum possible travel of the advance weight (and effective distributor advance). All of these parts are no longer available. If any are damaged/lost then one many need to either send the distributor to someone that knows and has spare parts... or one must buy a used/replacement distributor... or be resourceful enough to make new parts made including springs with various spring rates.
    Lastly, ensure you check the inside portion of the "cup" that the pins rub against. You will note that one pin (on each advance weight) is in contact with the cup at all times, whereas, the 2nd pin will only contact the cup once the distributor has advanced sufficiently. Because the "pins" do contact/rub the surface, then can cause the surface to wear and at times creating a groove/pocket that prevents the pin from freely sliding across the surface. Attached is a picture of what can happen... which happened on my 512BB. What it manifests is an inconsistent advance curve which can become "stuck". In my case, slowly changing the idle speed... like casual driving, which cause engine running issues, the distributor was not advancing or retarding like it was supposed to. Fast idle changes would have enough momentum to allow the pin to transverse the worn pocket. It took a while to discover this and was only found after I ruled out all other possibilities and spent time on my distributor machine where I noted the inconsistent advance curve.
    To ensure that this does not happen, ensure that the inner cup is greased so as to minimize the pin head friction against the inner cup. In my case, I have to weld up the divot, then machine the surface, and then treat the surface to minimize friction/wear.
    Cheers,
    Sam
    71Vette and Schumi like this.
  15. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Hi Sam,
    Mine actually looked quite good - the cup and rubber inner "bearing" show very little signs of wear, but the pins did have slight wear marks.
    Depending on what my measurements say, I'll consider sending it off to be reconditioned.
    Alternatively, I've thought about adapting a MSD 6AL-2 programmable box. #6530 has programmable timing, so you'd have to block the advance mechanism (at max advance) and copy the Ferrari curve as "retard" vs. rpm.
    Cheers
    Esben
  16. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Hi!
    The plan is to check the ignition timing this afternoon.
    I've made an Excel sheet with the target advance numbers, but noticed discrepancies between the text and the diagram in the Owner's Manual (not the first to do so, see https://www.ferrarichat.com/forum/posts/136371777/).
    The text says 8° advance at 1000rpm and 30° advance at 5000rpm. The diagramm however only shows 9,75° at 2500rpm (distributor), so 2*9,75° + 8° = 27,5° at 5000rpm....
    What's correct?
    Esben
  17. samsaprunoff
    4,456
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Esben,
    Sounds good. I suspected that many of the items I mentioned you would have looked at... but the worn "divot" on the inner cup was a new one for me and so I wanted to highlight this. I am still confused as to how it could have worn such a defined area... and only on one side? It is an odd one and threw me for a loop for a sometime, as I never looked at this area so closely and at the right angle that made the issue stand out.
    As for the programmable MSD box... sure, this could certainly work. In fact, I started work on a design that would allow one to retrofit these distributors to be used with "regular" (non programmable) MSD and other electronic modules, but with a fully programmable advance (via Laptop or Smartphone). My approach is somewhat unique and does not require any permanent modifications to the existing equipment ... and to the naked eye would look totally OEM (assuming one maintained the original electronic ignition module that had its guts upgraded to a newer device). I had hoped to have my design a bit farther along, but alas, one work project has consumed a lot of my time... Hopefully I can get back to work on what I am thinking, as if so, then dealing with the original advance mechanism could be gone. I will create a thread on all of this, once I am further along.
    Cheers,
    Sam
    71Vette likes this.
  18. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Problem solved!!!
    The distributor was on "wrong", off by one or two teeth on the shaft. I'm not actually sure what the timing was, as I couldn't get any sensible readings.
    However, after fitting the distributor correctly, we managed to set the timing as per the book - 8° btdc @ 1000rpm and 30° btdc @ 5000rpm.
    We also checked a few points in between, and they were also close to spec.
    All the bucking and jerking has now gone - I now have properly behaving Ferrari
    Cheers
    Esben
  19. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Here the comparison of the target advance in blue vs. the actual advance in orange - not too bad I think!
    Cheers
    Esben
  20. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    In one of your posts, you said it was almost out of the adjustment range of the slot or something similar. I was thinking that all depends on how the distributor was installed. Now you figured it out. Great perseverance and using good logic to solve a 400i issue!! You will need both in the long run with the car!!
    Ken
    71Vette likes this.
  21. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Thanks Ken!
    DIY-fixing my cars and bikes is the only way I could possibly afford to run them, and experience also tells me that about 99% of workshops, even self -professed experts, haven't actually got a clue. The ignition timing here being a prime example!
    I'm an automotive engineer, so I suppose there is some "perseverance and good logic" in my head, but it's also very refreshing to work on cars that aren't controlled by bits and bytes :D
    Cheers
    Esben
  22. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Esben
    One of the things I did to make life easier working on the 400i was to make a couple of a D-size copies of the electrical wiring diagram. I used it FREQUENTLY for troubleshooting! Staples, Kinkos etc. can make the large copies. Keep up the good work.
    Ken
    71Vette likes this.
