400i Cam cover gasket and… | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Bubba5320, Jun 10, 2024.
  1. Bubba5320
    Bubba5320 Karting
    Apr 18, 2024
    109
    Phoenix
    Bubba
    Well I believe I’ve located the oil leak onto my exhaust manifold heat shield. I think it be the cam cover. Either a seal or the gasket. How much of a nightmare is this repair? Don’t think I will tackle this myself but if my mechanic does it how much work is it? Thanks for any pre knowledge before my visit to the repair shop.
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,346
    Lyon (FR)
    R. Emin
    I assume it is under the plenum. That's not horrendous, but quite some parts to remove and re-install.
    I would say 2hrs?
  3. Rifledriver
    37,106
    2 hours?????? Have you ever done it? 2 hours. Thats funny.
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,346
    Lyon (FR)
    R. Emin
    I am much more used to the left side :)
    He is not talking about shiming the vavles, or disconecting the chain, just replacing the gasket of a single camcover of a single bank. Also this is a 400 "i", which is less work than when you've got to mess with carbs.(I am also assuming he cuts the gasket so as to replace it on a single camcover).
    If you venture in all the usual "while you are there", this could another (expensive) story, but if he sticks to a gasket, that's "not horrendous" (please note that i did not say it was "easy", just "not horrendous"...)
  5. Rifledriver
    37,106
    No. You said none of that. You said it was a 2 hour job which is total BS
  6. raemin
    raemin Formula 3
    Jan 16, 2007
    2,346
    Lyon (FR)
    R. Emin
    I don't mean to argue with you but, your answer is rude (to say the least).
    Let's keep factual: it obviously took me less than 2h45min (see the timestamp) to drop all the ancilaries of this particular cylinder head, and:
    1) there is less work involved in the OP request.
    2) Any professional mechanic is much faster than I am.
    3) I have no rememberance on what I also did on this particular day, but as I do not perform it for a leaving, I probably had a chat, a coffee, etc... between these two shots! At least I had to backtrack on what I was doing (testing the k-jet pressure judging by the tools installed)
    We may argue all day long on what's involved in this particular task, but at the end of the day it will not be much, and the OP is not going to break the bank in order to fix this leak.
  7. Rifledriver
    37,106
    Bubba, you were right to ignore this thread. This guy is an idiot and the last person you should be getting information from.
  8. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    I spent almost 2 hours just cleaning the mating surfaces...
    Rifledriver likes this.
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    2,346
    Lyon (FR)
    R. Emin
    A wood chisel does help.
