400i coolant caps | FerrariChat
400i coolant caps
Discussion in '365 GT4 2+2/400/412' started by usmck9, Aug 13, 2010.
  1. usmck9
    usmck9 Rookie
    Jul 21, 2008
    15
    Norman Baker
    #1 usmck9, Aug 13, 2010
    Anybody want to state which cap should be fitted to the radiator and which cap should be fitted to the recovery tank? I think I've had mine reversed for a year, now. 35477
  2. britalian
    britalian Karting
    Feb 10, 2006
    64
    Atlanta
    LL
    #2 britalian, Aug 14, 2010
  3. wil
    wil Rookie
    Apr 17, 2008
    27
    Barcelona (Spain)
    Willy Nuez
    #3 wil, Feb 27, 2011
    By the photo I took today it seems I had them the wrong way since I bought the car...
    I tried to remove the two ear cap but was stuck...
  4. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    The 400i radiator is designed for all normal expansion to take place in the radiator. The expansion tank should never see overflow and return coolant on cool down. Level in the radiator is set half way up top tank for expansion. The pressure / vacuum cap should be on the radiator. The non-pressure cap is on the overflow tank.
    I think I am right on this one but willing to hear otherwise.
    Ken
  5. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    Ken, On this one you are wrong Britalian is right.
    I had a thread on this awhile back when I discovered after two years of my car pissing coolant, that the pressure cap does go on the expansion tank and the plain cap goes on the Radiator.
  6. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Thanks for the interesting read on coolant caps.. I need to order two new caps today as my coolant overflow cap is now leaking..that said, these caps have been on my car since before I bought it 15 years ago, though I have changed the coolant every two years, the coolnt cap is just now fatiguing...also both caps read 16lbs., and that's higher than the reccomended .9 bar or 13.8lbs...She's an early 1980 series 1#28903..all thoughts and suggestions welcome..and as usual, thank you all so very much in advance..also.. I am hoping to post details and some pics on my auto tranny R&R along with the refurb on the propeller shaft..Many thanks to Brettski.. and also the installation to the new "Brit" starter..also I have Designed a completely new set of fuse boxes with blade fuses..sorry for rambling, and thanks again...Jacques.
  7. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Fritz
    I will check my books good and if your are right I will switch. It is interesting that it works okay my way too.
    Ken
