400i distributor cap | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Piston.Broke, Apr 17, 2021.
  1. Piston.Broke
    Piston.Broke Karting
    Mar 5, 2009
    50
    Australia
    Rick
    Hi all.
    I am looking at replacing the distributor cap on my 1979 400iA (Single coil). I have read on previous threads that the Jaguar Marelli V12 cap (Dual coil) can be used as a direct replacement. (It has certain price and supply advantages over the original).
    I have 4 questions:
    1. Is the following cap 'Intermotor Distributor Cap 46952' a direct screw in replacement for the original?
    2. Can the original Ferrari Rotor be retained for use with this cap or is a new Rotor required?
    3. Can the dual coil cap be used by simply connecting up the single coil to the central coil tower and leaving the second coil post vacant?
    4. Has anyone else carried out this change of distributor cap and if so were there any problems in doing so?
    Thanks in advance for any advice/assistance.
    Cheers!
    Piston.Broke
  2. rovexienus
    rovexienus Formula Junior
    548
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    Some of the questions are addressed in this post: https://www.ferrarichat.com/forum/threads/v12-distributor-cap.543109/
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    1,759
    Lyon (FR)
    R. Emin
  4. Piston.Broke
    Mar 5, 2009
    50
    Australia
    Rick
    Thanks Rovexienus and Raemin.
    I have read the older thread but there is a lot of somewhat confilcting information and the answers to my questions arent necesarlily clear.
    I am sure that someone who has used these dist caps can answer my questions directly.
    Cheers ! and thanks for the initial responses.
    Piston.Broke
  5. markcF355
    markcF355 F1 Rookie
    3,486
    Schmeckelstan
    Mark
    Yes, that cap will work. You just use the center coil terminal.
  6. Piston.Broke
    Mar 5, 2009
    50
    Australia
    Rick
    Thanks markcF355.
    Did you use the original rotor button (Ferrari) or was a new rotor required?
  7. markcF355
    markcF355 F1 Rookie
    3,486
    Schmeckelstan
    Mark
  8. Piston.Broke
    Mar 5, 2009
    50
    Australia
    Rick
    Thanks so much markcF355 for the info.
    This has been very helpful.
    I will go ahead and order the Jag cap and keep my original (slightly damaged) cap as a spare.
    (I know that the 400i isn't a Testarossa or GTO, but I do love it and I keep all the original equipment with it when I have needed to fit aany replacement parts).
    Thanks again to everyone who provided insight/advice.
    Cheers!
    Piston.Broke
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    1,759
    Lyon (FR)
    R. Emin
    These are the same cap except that the jaguar gas an
    The distributor cap is buried under the windscreen, one would hardly notice the additional HT plug of the the jaguar cap. In any case, Superformance does sell a proper cap (actually not perfect as you do have to trim it a bit in order to fit the EMF shield), so if you want to do some concourse, reverting back to stock is not such an issue.
