400i fuel pumps....? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by YorkieV12, Jan 24, 2015.
  1. YorkieV12
    YorkieV12 Karting
    May 23, 2014
    132
    There seems to be a very wide range of pumps and prices for these cars.
    Does anyone have a particular recommendation of type and/or source.?
    NB....I'm in the UK
    Thanks.
  2. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    The same basic Bosch pump is sold as several different part numbers each with different inlet and outlet fittings depending on the car. Unless you want to change hose fittings you should stay with same part number. Yes, there is a wide range of prices. I only know US sources.
    Ken
  3. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I used this brand. worked and cheap. I do not remember the part number.
  4. 308mon
    308mon Karting
    Oct 5, 2014
    169
  5. YorkieV12
    YorkieV12 Karting
    May 23, 2014
    132
    308 MON
    Thanks for that, I have been considering their pumps. Connections not important as I am replacing the entire system of pipework.
  6. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    I bet they do not have the high surge power on start up like the Bosch.
    Ken
  7. scs550
    scs550 Rookie
    Dec 25, 2012
    37
    Germany
    Sven
    after being on my fifth (!) Bosch fuel pump within 9 months and 2000 km, I would be very interested to know which pump is working fine on your cars.
    Always the new Bosch pumps seem to last ~300 km, then - always on the same bank - the pump was broken. And, no it was not just fuse box, since the pumps were really broken afterwards.
    Any advice is appreciated!
    The pumps were always replaced on guarantee by Ferrari, so I did not mind too much. But nevertheless, it was not confidence inspiring on a longer trip... and on 6 cylinders, it is rather "limp-home".
    Somehow, I have good feeling this time it will last somewhat longer since it is a slightly used older pump that I wanted to try out .... let's see.
    Call me optimistic ;-)
    Best regards
  8. Elasto
    Elasto Karting
    Aug 27, 2014
    142
    Vienna, AUSTRIA
    Andreas
    Hi Sven,
    fuel pump problems? are you the owner of the silver pavesi with red interior?
  9. scs550
    scs550 Rookie
    Dec 25, 2012
    37
    Germany
    Sven
    Hi,
    yes, the 1980 grey/red Pavesi Convertible...and very happy with it except for the fuel pumps ;-)
    How is your 400iA doing that I looked at in Vienna?
    Best Sven
  10. Elasto
    Elasto Karting
    Aug 27, 2014
    142
    Vienna, AUSTRIA
    Andreas
    left front tyre is loosing pressure slowly (4 brand new tyres) and and the power window on the pax side is making a terrible noise. other than that ..... fine.
    Greez, Andreas
  11. Steve Magnusson
    26,794
    Has the Shop measured/confirmed the regulated supply pressure after replacing the pump(s)? If the pressure regulator section inside the fuel distributor wasn't working correctly (and the regulated supply pressure was too high), this would put added stress (both electrical and mechanical) on the pump -- but the mixture could still be OK because that is set independently (at whatever value the regulated supply pressure is - even if it is wrong). Just a thought....
    Alternatively, measuring the current to run the pump might give the same clue -- a new (tight) CIS pump should be in the ~11A ballpark. If it was more like ~15A, I'd suspect the regulated supply pressure is too high.
