400I ignition wire question | FerrariChat
Discussion in 'Technical Q&A' started by Joccomo, Mar 14, 2006.
  1. Joccomo
    Joccomo Rookie
    Mar 14, 2006
    1
    My mechanic is working on a 400I and asked me to post a thread. His computer is down, and his amazing fixit skills are limited to sportscars. So, here is his question.
    The vehicle is a 1983 400I and he was wondering what type of ignition wires can be used on the vehicle. The car came with CAVIS 400 ignition system; magneti marreli.
    Any suggestions welcome. He is in the middle of a full rebuild on the engine.
    Joccomo
    Feel free to email me directly at [email protected] with any help.
  2. Steve Magnusson
    26,776
    From the "not blowing up the internals of the ingition electronics" view, I believe as long as you roughly match the Ohms/length value of the new wires to the old wires (and use the stock "resistor" or "non-resistor" spark plug -- whatever is specified for your model) there's no additional risk, and it should operate OK.
    Do you have a rough Ohms/length value measured from your old set or a stock 400i set?
    (Are these so expensive that you need to find an alternate? Have you priced a stock set from the FerrariUK/Maranello C website?)
  3. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    Try Kingsborne for new wires.
    They can supply solid or spiral wound copper core high quality wire, with resistor or non-resistor sparkplug extensions. Also heavy duty distributor end rubber boots, and high temp wire cover material in various colors.
    I bought a set for my Boxer for about $200, and couldn't be more pleased with the quality and workmanship.
    http://www.kingsborne.com/
