400i Radiator fans | FerrariChat
400i Radiator fans
Discussion in '365 GT4 2+2/400/412' started by Piston.Broke, Jan 29, 2013.
  1. Piston.Broke
    Piston.Broke Karting
    Mar 5, 2009
    51
    Australia
    Rick
    I need to replace the electric radiator fans on my 400iA.
    Has anyone done this? If so, are you aware of a suitable replacement for the initial fans fitted?
    Thanks.
  2. Ak Jim
    Ak Jim F1 Veteran
    9,631
    North Pole AK
    Just curious, are your fans inop or are you looking to upgrade the cooling?
  3. Piston.Broke
    Mar 5, 2009
    51
    Australia
    Rick
    Hi,
    The car sometimes runs hot when climbing hills and I discovered that the Right hand electric radiator fan is seized. I thought that this may be influencing the overheating problems and have removed the OEM fan to replace it. I have also discovered that the Left hand fan isnt too good either so I thought might upgrade/replace both fans.
    Cheers !
  4. alastairhouston
    alastairhouston Formula Junior
    Apr 19, 2009
    575
    Largs Scotland UK
    Alastair Houston
    Hello
    I have fixed these before by replacing the bushes using old bushes from a hoover or such like it is a little time consuming but possible,
    The car doesnt need extra or upgraded cooling as it was designed seems to work fine for me anyway as I have given it plenty of abuse and never had any issue including stuck in traffic jams for long times etc.
    'Superformance' have the replacement fans cant remember the price but I have also replaced and they work perfectly well.
    Regards
    Alastair
  5. alastairhouston
    Apr 19, 2009
    575
    Largs Scotland UK
    Alastair Houston
    Rick
    further to last, you definitely need both fans working.
    Alastair
  6. Piston.Broke
    Mar 5, 2009
    51
    Australia
    Rick
    Thank you Alastair,
    I also thought about just replacing the internal bearings but time is the enemy !!
    I will check out the replacement 12v electric fans at the local autoparts suppliers.
    Cheers!
  7. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Having owned and ope
    rated my 1980 400i in Florida for about fifteen years, I have some thought on this.
    first..if you have the old style long motor bodys..they are the same fans used it the Jag XKE's, and the bushings are very much available. If you want to replace the old motor, they are available at GRAINGERS..yup..same motor with better technology..However, if you want to update the fan system with more modern and more effective fans, SPAL and others make very nice replacements that draw way less amps with better fan blades...Also,go to the 308/328 forums, as the have tons of threads ad-nausium on the subject. I hope that this is of some value. Happy Trails. Jq.
  8. dstacy
    dstacy F1 World Champ
    Jan 23, 2006
    11,998
    GMT -5 & GMT +1
    Dave
    If they are the ones in FRONT they are the same as Jaguar
  9. jacques
    May 23, 2006
    877
    Los Angeles/Florida
    Just tying to help..GEE.Jq.
  10. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    A SPAL fan would be a good match for the fan pulling from behind the radiator. It should be easy to fit.
    My fans improved when I added local relays to each fan instead of bringing the power thru the XXXXXX fuse/relay panel.
    Ken
  11. Piston.Broke
    Mar 5, 2009
    51
    Australia
    Rick
    Thanks Ken, Dave and JQ,
    Excellent info and yes, very helpful.
    The fan I need to replace is a 'pusher' (in front of the radiator) and although it may be difficult to source, at least I know that it is similar to some of the earlier Jag units.
    Sounds like a good idea to fit the relays as well.
    Thanks for all the advice.
    Cheers!
    Piston. Broke
  12. shaughnessy
    shaughnessy Formula 3
    1,869
    Wolfeboro NH
    Thomas E Shaughnessy
    I need a pair of used fan motors too
    Same from 1969 thru ______
