400i starting problems | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by i-velocita, Jan 27, 2008.
  1. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    My 1981 400i will not start. When I turn the key it sounds like the starter binds (doesn't turn, just sounds like it's stuck) and the ammeter goes to the low end of the gauge. I removed the apark plugs and tried again with the same result. Wacked on the starter with a wrench...the same. Any ideas? Thank you!
  2. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,226
    MA
    How long has it been since it last started and ran? Was it running okay when it was last shut down?
  3. Steve Magnusson
    26,785
    You did the right thing to remove the plugs (just in case a cylinder had filled up with coolant). Next step would be to see if you can manually rotate the crankshaft by driving the big nut at the snout -- if not, remove the starter (which I know is a beyotch on a 400) and try again -- if still no go, a very bad sign.
  4. i-velocita
    2,520
    Colorado
    James
    The car ran fine until last fall. I parked it in the driveway and it would not start. Have not started it since. At the time, the starter just clicked or sounded like it was spinning without engaging the flywheel. Now the starter sounds like it is stuck.
    If I try to turn over the engine from the nut on the flywheel, which way do I turn it? In other words, if I am facing the front of the car, do I turn it clockwise or counterclockwise? Do I need to put the automatic trans in neutral?
    Thanks!
  5. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Not being sure of what the fastening torque is on the crank bolt and keeping "Lefty loosey, righty tighty" in mind I'd turn it clockwise as you face the motor so as not to loosen it. With the plugs out it should turn pretty easy.
    From what you have described it sounds as though the starter has died, perhaps just the solenoid.
    It doesn't matter what gear you're in if an automatic, put it in neutral if a manual box.
  6. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    A few months back I had exactly the same syndrome with my 1980 400i..It turned out to be two things at the same time in my case(so what else is new),,,the starter ($900 very old technology) needed to be rebuilt..the parts as I found out were available at Algar..at that time only two sets were in captivity in the U.S...so they're probably gone by now..I found a WODERFUL shop locally that was able to fabricate the parts for $90..dig it... third generation shop..Also..to remove the starter..You MUST remove the exhaust manifold in two pieces..amazingly easy one you accept the fact that starter is way too large to squeeze out..you must put it on a high lift..it takes one hour and a very stubby 18mm and 19mm wrench to get in there..use plently of rust buster and let it work for a while gloves help ...next..the positve lead on my car was green with corrosion.impeding voltage to the starter solenoid.. made new one with marine 2guage.. easy..If it were me in this situation I would opt for the new high torque British Starter for $450 U.S. made specifically for the job..they're up in Massachusetts..British Starters.com. Had I known of them at the time, I would have gone this route be because these old Marelli starters just destroy your battery charge...also.. the 412's went to a Bosch starter quite available but again still slow cranking..Sorry to rattle on, but 10 years of ownership has shown me a few things...Jacques..I just hope this helps you.
  7. Steve Magnusson
    26,785
    #7 Steve Magnusson, Jan 28, 2008
    This is actually quasi-good news -- tilts the odds towards the starter itself.
    Clockwise. See the timing chain figure in your 400i OM -- item 16 is the driving gear on the crankshaft.
    Yes, Neutral (not Park) with the emergency brake "on" or appropriate wheel chocks.
  8. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    My starter went in the summer (similar symptoms to yours) and I had it replaced with one from British Starters - it spins the motor very fast, way better than the original. As Jacques says, the manifold must be removed, which I think entails removal of the injection unit.
    Good luck!
    Aidan
  9. jacques
    May 23, 2006
    877
    Los Angeles/Florida
    This is a straight forward operation..these manifolds must be removed from the bottom..they are in 2 pieces of 3 ports each..also..and this is imperative..unbolt them from the collector BEFORE you attempt to unbolt them from the block or you will create a severe torque situation on the bolts going into the engine block and you will break the flanges or strip the bolts... as I mentioned previously these bolts are usually quite rusty so use plenty of rust buster of your choice let them sit for at least 30-45 minutes minimum so that you don't round of the bolt he-heads..if you get in a hurry your 2-3 hour labor charge will pale by comparison from there on out..no fuel inection or gas lines are involved..I watch with amazement the senseless troubles people on this f-chat forum cause themselves by being impacient and sometimes too frugal (spelled cheap) to do things the proper way..I hope this helps...Jacques..remember that self-bonage is the worst bonage of all...
  10. i-velocita
    2,520
    Colorado
    James
    Thank you all for your input. I'll let you know how things turn out.
