Heat shields | FerrariChat
Heat shields
Discussion in '308/328' started by Corrupt File, Jun 17, 2013.
  1. Corrupt File
    Corrupt File Karting
    Jun 17, 2013
    111
    Canada.
    Good day all, just joined up to this form as I have been lucky enough to be given my dads 77 308GTB. It has not been used for ten years he is the original and only owner and I am having it serviced and put on the road again. The mechanics are suggesting I remove the heat shields from the headers. Yes it will save weight, but I have seen in another discussion about excessive heat in the engine bay. Was wondering if anybody has recently had any experience doing this and would you recommend it? The old saying "if it ain't broke don't fix it" comes to mind.
  2. Jonny Law
    Jonny Law F1 Rookie Silver Subscribed
    May 6, 2008
    3,203
    Over yonder.
    IT Guy
    Removed the aluminum covers from the heaters and had the entire exhaust system ceramic coated. Still finishing up the winter project, so not sure yet what the heat reduction will be yet. I think the euro models don't have the aluminum heat shields.
  3. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    If you simply remove all the covering and do nothing, there will be parts of the headers uncomfortably close to units such as the starter motor. Euro cars dont have the covering but have additional aluminium heatshields added instead.
  4. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    I'd leave it alone unless you're replacing them with something better. Did the mechanics give some kind of reason other than weight reduction? Doesn't seem like much weight to begin with.
  5. Corrupt File
    Jun 17, 2013
    111
    Canada.
    He says the insulation will have stopped doing its job, and just absorbs water. He has also removed lots of heat shields on other 308s with out any issues.
    Thanks for the replies.
  6. Lorzen
    Lorzen Formula Junior
    Sep 20, 2011
    343
    NYC Metro
    Water from where...just say no...
  7. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    At some point in the future, I plan on removing the shielding and then coating the headers inside and out.
  8. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    If you drive it in the rain, there is a good chance the headers will get wet...mine have some cracks in the shielding. I could definitely see how moisture could get in there. Luckily mine has lived its whole life in good conditions, so no excessive corrosion.
  9. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    It's spun asbestos in there, not cotton.
    It's not holding water
    You WOULD be able to see stress cracks before they blow out, but sometimes it's better not to know.....
    Congrats that's the BEST year!!
    :D :D :D
  10. BigTex
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    The headers themselves are stainless tubing..
  11. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Welcome to the chat. Just about any question you could ask has been asked before. Do a few trial tests of the search function and you will find an immense wealth of owner experience and many professional responders to help us all.
    Like you, I have a 77. I also inherited my fathers one owner 74 911 and it was a real eye opener to discover the car's condition and get to setting things right.
    On a car that has sat for 10 years, I can think of a zillion things to do before removing the header heat shielding.
    First and foremost would be the condition of the brakes, closely followed by the timing belt condition, (good for about 5 years with good reliability).
    I would recommend you sit down with the people your dad had maintain the car, (if you get the feeling that he really trusted them) and talk about the condition of the car and what maintenance is past due, due now and what you can look forward to in the near future.
    The 308 is not a complex car by today's standards, but there are some things that really have to be done right or it can get real expensive.
    Do you want to do any/some/all of the work on the car???
    What is your situation??
    We are here to help,
    chris
  12. newto308
    newto308 Karting
    Mar 20, 2007
    92
    McLean, Virginia
    Chris
    I had my headers ceramic coated after I removed all the aluminum and insulation. The headers are cool enough to touch within one minute of engine shut down, even after hard driving.
  13. Jonny Law
    May 6, 2008
    3,203
    Over yonder.
    IT Guy
    The other advantage to removing the covering is that you can see if the header is cracked or broken.
    I had the material from under the heat shield that protects the vent tube tested, it was a very fine fiberglass. I'm pretty sure this is a the same material on the headers.
    I am wondering what this will do to the emissions test.
  14. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    Should be good, the coating keeps the heat in.
  15. Corrupt File
    Jun 17, 2013
    111
    Canada.
    Oh believe me my friend, it's not just heat shields. I'm just asking the opinion of all the members on this form on that topic. All those hoses belts are of and being replaced. I'm havin a major service done to it. As you mentioned the calipers, they are in great shape, just replacing the pads.
  16. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I had a '78 GTS and when I did an engine-out on the car, I removed the covers and insulation from the headers. I then sent them to Jet Hot and had them coated inside and out by them. I did them in the Jet Hot silver and they came back looking great. The heat level in the engine compartment actually went down after removing the insulation and having the headers coated. The Jet Hot silver held up really well and showed no signs of peeling or color change right up until I sold the car.
    If your mechanic is going to strip the insulation, I would definitely recommend having the headers coated, inside and out. I have used Jet Hot several times and been very satisfied with their work and quality of coating. YMMV, and you might use one of the other services people mention, but either way, do consider having them coated. Don't leave them bare.
  17. Nuvolari
    Nuvolari F1 Veteran Owner Silver Subscribed
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    First of all congratulations on the acquisition of the 308. A one owner car in the family from new is really cool.
    Regarding the headers please take my advice and REMOVE THE ENGINE. Taking off the front header when it is shielded on a 308 is brutally hard with very little access. With the engine out it is very simple. Also because the car has sat so long there are tons of things to do in the engine bay and with the engine out every single one of them will go much much faster. Pulling the motor on a 308 is really simple and the in and out time will be more than made up on labor in struggling with an engine that is installed. Not only that there will be a ton of extra jobs you can do to get the car road ready for the next decade.
    Regarding the headers I have done this job and totally recommend removing the shielding, plugging the air injection holes and lastly ceramic coating the headers. In my case the under hood temperatures noticeably went down. Good luck with your project.
    Andreas Engesvik likes this.
  18. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    He asked if they get wet, which they do. Lots of cracked and leaking headers out there made out of stainless.
  19. Jonny Law
    May 6, 2008
    3,203
    Over yonder.
    IT Guy
    If you are removing the air pump system, talk to smg2 about a set of air nozzle plugs. This will eliminate the whistle that is created by the holes left behind.
  20. bill308
    bill308 Formula 3 Silver Subscribed
    May 13, 2001
    1,224
    Windsor, CT
    Bill Sebestyen
    The header insulation may get wet on occasion, but the header heat will quickly dry them out.
    Bill
  21. 4right
    4right F1 Rookie Rossa Subscribed
    Sep 14, 2008
    2,966
    US/Japan/Singapore/Canada/US
  22. George Vosburgh
    George Vosburgh F1 Rookie Silver Subscribed
    May 26, 2011
    4,367
    Pittsburgh, PA / Chautauqua, NY
    I have a '77, just did the headers in ceramic coat.
  23. Corrupt File
    Jun 17, 2013
    111
    Canada.
    Thanks again for all the great advice and replies. The engine was taken out, had the heads cleaned, putting in new valves, as the originals were in there. The o2 pumps were taken off by the dealer in 78, all maintainence had been performed by said factory dealer until now. Don't recall any whistling besides the sonic beauty of those lovely webers singing their tune :). Shocks springs are all original and ring replaced. Ill have to inquire about this ceramic coating. As for smog emissions, I live in Canada, don't have to abide by the California standards ;) sorry for you guys that have to.
  24. enzo777enzo
    enzo777enzo Rookie
    Oct 29, 2013
    43
    Argentina - La Pampa
    hello
    i buy my car a not have heat shield in manifold.- I want made theys (2) in hard alumine.-
    Please.- Can someone send pics of shields??? and measures??
    Regards
    Enzo
  25. Jamesg68
    Jamesg68 Rookie
    Jul 27, 2014
    17
    BOSNIA & HERZEGOVINA
    JAMES G
    From the picture of the engine bay, can someone tell me what is the grey material sprayed/rolled onto the body(inner trunk wall) between the exhaust header and the trunk, is it heat shield, is it sprayed on, rolled on, what is it and how is it applied?
    Any advice would be greatly appreciated
