412i Battery Drain - Turn Signals When Switched Off | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by jhkm12345, Oct 22, 2025.
  1. jhkm12345
    jhkm12345 Rookie
    Mar 17, 2015
    21
    Atlanta, GA
    John M
    I've done quite a bit of digging on the forum and have come across a few posts relating to turn signal repair, but not so much their appropriate function.
    I'm chasing down a draw on the battery and am suspicious that it is somehow related to the fact that the turn signals are functional with the key turned off.
    Can anyone confirm or deny that the turn signals should come on or illuminate steady with the key turned off?
    This is a 1987 Euro 412i
    Also, any sources or shared wiring diagrams would be greatly appreciated!
  2. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,683
    Romulus, NY (Finger Lakes)
    Ken Battle
    In Europe and on many Euro cars, when people park on a street at night, they leave the outside turn signal on and it does not flash when the key is off. Maybe the Euro 412's had that feature, but it WILL run down a 412 battery overnight.
    I solved a battery draw problem by putting an ammeter on the main battery cable. I saw a small but significant draw with everything OFF. I pulled the fuses one at a time and found the draw was from the rear window defroster switch/wiring which was disconnected when a new rear screen was fitted (by a prior owner). Disconnecting the switch did the trick. You will need a good ammeter to do this check.
    Ken
    Ak Jim likes this.
  3. jhkm12345
    jhkm12345 Rookie
    Mar 17, 2015
    21
    Atlanta, GA
    John M
    Thanks, Ken. Yes, I am familiar with some euro makes/models leaving a marker light on when the key is off and the signal switch is engaged. Not sure what the rationale is for that, but I get it! Curious if this is the case on the 412 though. My signals and hazards are all operating as they should, with question of signals working with key off.
    I have already pulled each fuse and relay, individually, to find no impact on draw. I'm chasing a ghost - likely a short or damaged wire somewhere along the way.
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,411
    Lyon (FR)
    R. Emin
    As the turnsignal relay is used for the warning, its powersupply must come from a permanent power supply (not an acessory supply).
    You could use an ampmeter in lieu of a.fuse is norder to identify parasitic power draw.
    Courtesy lights (including in the trunk) can deplete the battery if the switch is not properly locked when the lid is closed.
  5. Steve Magnusson
    27,008
    Have you checked your "Conversations"?
  6. jhkm12345
    jhkm12345 Rookie
    Mar 17, 2015
    21
    Atlanta, GA
    John M
    I have and just replied. Thank you for your thoughts and recommendations.
  7. Ak Jim
    Ak Jim F1 Veteran
    9,832
    North Pole AK
    I would remove the bulb from the trunk light and see what happens. Maybe put the wife in the trunk and close it and she can check if the light is still on?
  8. raemin
    raemin Formula 3
    Jan 16, 2007
    2,411
    Lyon (FR)
    R. Emin
    An active phone camera is a less risky approach...
    Ak Jim likes this.
  9. Rahtok
    Rahtok Karting
    May 8, 2019
    69
    Seattle WA
    Brian
    Ba ha ha. But where's the fun in that??
