Small aircraft weight & COG system | FerrariChat
Discussion in 'Aviation Chat' started by keelaboosa, Oct 7, 2013.
  1. keelaboosa
    keelaboosa Formula 3
    1,820
    San Marcos, CA
    Andy
    I'm no pilot and am not in any aeronautic field, so please excuse my naivete. I do have a background in load measurement systems.
    It would be very easy to outfit small airplanes with instrumented axles so pilots could verify aircraft weight and center of gravity prior to takeoff. With the number of accidents due to overweight or out of trim conditions it seems this would be a no brainer.
    Is such a system available? Any reason something like this shouldn't be pursued?
    Thanks in advance for any insight.
  2. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    It is used by Boeing on their big tin birds.
  3. keelaboosa
    1,820
    San Marcos, CA
    Andy
    That's all I turned up in a quick Google search. I've got to think you could offer replacement axles for 172's with instrumentation for $5k or less.
  4. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    It would be interesting, but as a Private Pilot I can easily make my weight & balance calculation and would not be willing spend very much money for a system that would at most verify my calculation and if not make me suspect it was out of calibration or something like that. I'd rather spend that kind of money on an angle of attack indicator.
  5. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    And how much would this system weigh (both the measurement and display parts)?
    If it was more than 10 pounds, it probably wouldn't be a very popular option (payloads are very limited on small planes).
  6. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,291
    Northern CA
    Yin
    Another factor to consider in the cost/value tradeoff, is that you might have to get it certified by the FAA since pilot/owners would be relying on it for a go/no-go decision.
  7. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    True.
    And it is real fast to do if you set up a simple spreadsheet for your specific airplane.
  8. keelaboosa
    1,820
    San Marcos, CA
    Andy
    I figured this should be a relatively straight-forward calculation, but there have been many accidents where this was the case. If they had a system that removed the need to do the calculation, or at least confirmed it, there ought to be value in that. Maybe reduced insurance rates for planes with the system installed and a valid certification?
  9. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    It's not worth the trouble. It wouldn't weigh but a few pounds, if that, but any pilot (at least any that passed the FAA private exam) can calculate the weight and balance in a few minutes. At most you could keep a scale in the hangar to let you know where you were, but come on, it's really easy and it's not a real issue.
    The real problem is pilots not bothering to calculate weight and balance, or probably just as often, ignoring the fact that they are overweight in the first place, when they know darn well that is where they are.
  10. keelaboosa
    1,820
    San Marcos, CA
    Andy
    Definitely less than 10 lbs. Strain gaged axles, 20' of wire, small display/controller.
  11. keelaboosa
    1,820
    San Marcos, CA
    Andy
    That's the people who need something like this. Nobody will admit to themselves they're negligent, and maybe in most cases it's a step that can be "roughed out". But if you had an indication that your plane were overweight or the COG is out the window you might stop and consider the problem before blindly taking off.
  12. keelaboosa
    1,820
    San Marcos, CA
    Andy
    Absolutely. It would have to be a certified piece of kit, and it would need yearly checks to maintain the certification (I would think). I like that barrier to entry from a business perspective.
  13. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Most airplanes listed weight is usually wrong. Trying weighing your plane and see just how far off the weigh is from what your records show. We forget the tools, the miscellaneous items in the cockpit, and we don't adjust the weigh for paint touch up, etc. I put a glass cockkpit in my plane. Should have reduced the empty weigh. Didn't, weight went up by 100 pounds. Something had gotten missed over the years.
    Art
  14. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,463
    Southlake, TX
    Rob Lay
    #14 rob lay, Oct 7, 2013
  15. Tcar
    Tcar F1 Rookie
    Also would deal with the passengers fabricating their weight...
    Happened in a chopper crash not too long ago. A number of people gave their weights as 120-125; in reality they were all 150 or more.
    Crash; all died.
    Should pilots weigh their pax? This would do it.
  16. keelaboosa
    1,820
    San Marcos, CA
    Andy
    That was actually what prompted me to think of this. It's awkward asking a woman her weight, especially if she's on the heavy side, and there's a good chance of getting a "generous" estimate from them if they don't understand what the minor fib might lead to.
    When I go offshore via helicopter me and my baggage are weighed. That's apparently not a requirement.
  17. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    reminds me of the time I watched a pilot unload the contents of a fully packed station wagon into a Bonanza, had the fuel topped off, and four of them climb into the plane...as they taxied away the nose wheel would bounce clear of the ground as they crossed some irregularities in the tarmac... a strain gauge would offer little except to sound an annoying alarm for a bad cg... this guy was going regardless of the weight and balance...
  18. kylec
    kylec F1 Rookie
    3,663
    Orlando
    I was in a caravan and everyone had to step on a scale at the terminal before we wen't onto the tarmac. They sat the heavy Hawaiians towards the front.
    They also had a bathroom scale in the baggage compartment.
  19. rob lay
    Dec 1, 2000
    63,463
    Southlake, TX
    Rob Lay
    I weigh bags and passengers if anywhere close. Rarely am I close as wife weighs model +/- 5 lbs and Mia about 40. Also the 400 would have 200 lbs more gross if not for the brakes.
  20. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,649
    Oregon
    Gabe V.
    Don't forget your air density factor.
  21. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    As Rob mentioned, weight and balance must be REALISTICALLY calculated before loading. It doesn't take a computer driven calculator to accomplish on a small airplane. Plain ol' people have been doing it for a long time with plugging in total weight of payload, placement of the weight, fuel load, density-altitude, and good sense. Of course, I never paid any attention to that when I was flying a puddle jumper.
  22. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Also, if you take the same combination of people with you on certain trips, then you can re-use a previous calculation (assuming the weights haven't changed much and your well within the limits).
    An example of this is when you take lessons with a specific instructor and you typically fill up the tanks to the bottom of the tabs. So, you know you're within the limits since nothing much has changed since your previous w&b calculation for the same passengers.
    But, if you take an extra adult in the back seat one day with your instructor, then that's when it is important to run the calculations.
    The density altitude performance calculations are a different thing altogether though.
    Once again, this can be done quickly and easily by building your own spreadsheet for your plane.
    Normally it is things like flying on a hot day, or to a higher elevation field, or to a shorter-than-normal runway that triggers one to run these calculations.
  23. Tcar
    Tcar F1 Rookie
    Could you explain, please? Talking about a Corvalis?
    Sorry for my ignorance.
  24. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,675
    Los Angeles
    Ferrari-tech
    I think the biggest hurdle would be getting it certified.
    There would be very little interest from the airframe manufacturers to invest in such a product, as they are never held accountable for the accident after a pilot over loads his plane and stuffs it in.
    As has been mentioned, I have a spread sheet on my laptop, and two apps on my
    I-phone, all of the 172's (all 3 of them :) ) I currently fly have different empty/full weights but a few clicks set the base settings and I fill in the rest...If I don't do the calculations its my fault.
    My school had me do a W/B before every flight after I had checked the tanks, of course I was always well with in the limits, but it was taught to me like it was part of the preflight
  25. rob lay
    Dec 1, 2000
    63,463
    Southlake, TX
    Rob Lay
    correct, not sure how things have gone with the Corvalis as that's been in Cessna's incapable hands since 2009 or so. however, the Columbia 400 has all the design and characteristics to handle 200 pounds more gross minus the brakes. the brakes are average at best and they wouldn't certify more weight for the obvious implications. the Columbia is an amazing airframe certified in Utility category with load factor of 4.4 and dual wing spars. several companies have talked about doing an STC, but there are so many headaches and costs with that for a smaller fleet. many of the old timers have the attitude "load 4 guys, golf clubs, and go!". Not sure they would pay much for the STC.
