Michelotto 308 build | FerrariChat
Discussion in '308/328' started by sp1der, Nov 20, 2013.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #1 sp1der, Nov 20, 2013
    Here goes the start of another major project, timeline is probably a few years and at the moment the plan is to build an accurrate period replica in terms of looks and some of the features. Plan is to have a higher perfoming road car, with major weight loss and improved safety compared to a standard car.
    Teardown of the car has started with work on the front end first, aim is to try and get the whole front clip off by the end of this week!
  2. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,995
    Pittsburgh, PA
    Fun project! Some rust on that bugger...how bad is it? Just surface rust or will any parts need to be replaced?
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Mainly surface and most of what is affected is being cut out anyway as part of the chassis mods. The front spoiler was a real pain to remove the flanges had been well glued as well as the bolts!
  4. singletrack
    Mar 16, 2011
    5,995
    Pittsburgh, PA
    Ahhhh...always fun finding those surprises from past people and wondering what the hell they were thinking... : )
    Slightly ahead here - but what wheels are you putting on it? : D
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Coffin spoke but I am tempted to use the Listerbell 16" frt and 17" rears simply to use modern tyres and again a nod to more modern parts brembo calipers. These will probably be the only major deviations in the build.
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,988
    Atlanta
    John!
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Wonderful. Looking forward to following along. Good luck.
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #8 sp1der, Nov 20, 2013
  9. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    cool another gr4 build
    where are the calipers from? did they fit the stock 16 inch wheels? on the fronts only or some uprated ones on the rear also? please tell us about the improvements over the standard binders...
    regards
    hf
  10. Omnivore
    Omnivore Formula Junior
    Jun 3, 2011
    436
    Portland
    Matthew F
    Oh my my. Oh hell yes...
  11. singletrack
    Mar 16, 2011
    5,995
    Pittsburgh, PA
    Schwing!!!
    I own that car...well 1/43rd that size ; )
  12. Omnivore
    Jun 3, 2011
    436
    Portland
    Matthew F
    Sp1der-
    Epic project. All props to you (in advance). I recently sold my S1 Elise 190 Motorsport which was easily the best track car ever. Locked diff notwithstanding. Relatively small (15" wheels) unsprung mass. Like an early 911 or 308. Quick and nimble.
    It's been said one builds a car around the wheels/tires.
    If you're going to go big with rolling stock, are you planning to have BHP to warrant big rubber and flares? If not, have you considered a Micholetto- inspired narrow body? Smaller hole through the air. Air resistance being the square of velocity.
    My 2p.
    Looking forward to following your project.
    Cheers,
    Matthew
  13. singletrack
    Mar 16, 2011
    5,995
    Pittsburgh, PA
    YESSSSSS!
    NOOOOOOO!!!!!
    Seriously - I hear you on the ability to use modern rubber. My God what a difference it makes.
    Can't wait to follow this.
  14. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    They are 355 calipers and discs and fit within the 16" wheels, but a small spacer is required. I will be changing to 2 piece discs but retain the calipers so the spacer will go.
  15. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    #15 JeremyJon, Nov 21, 2013
    That's going to be great Simon, and looking forward to seeing updates on your project!
    I've long thought a street version of that style 308 would be very cool to own, an ultra light body, deep spoiler, rosso corsa with gold wheels, done implementing some improvements along the lines of the Singer 911s
    Here's a couple of photos that inspires! :)
  16. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    The red car looks very similar to the one Foskers built in the UK. The deep spoiler however will not feature as it is just too easy to ground and snag on things. The one I have just taken off has been repaired a lot of times as the car is quite low.
  17. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Foskers have that car for sale right now
  18. sherpa23
    sherpa23 F1 World Champ
    10,023
    Rocky Mountains
    Bastuna
    #18 sherpa23, Nov 21, 2013
    I have a set of those coffin wheels on the way. And I really like that Foskers build.
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Are those the Listerbell wheels or the Hawk wheels you have on the way? Would be interested to know (if they are the Listerbell wheels) how they work out, quality, fit etc?
  20. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    what did you do on the rears with the e-brake? i suppose if you were to do gr4 car now you can use a fly-off tpye in the hydralic lines
  21. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    That VSOlioFiat car has my engine in it. At least, the short block dry-sump engine from car #21747.
    It was built by MAT, and they purchased the motor from Eurospares. I had sold my wrecked car to them.
  22. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Standard rear calipers at the moment but also have some brembos for the rear with small piston sizes so brake balance is almost same as stock frt to rear. Can then use fly off hydraulic brake as suggested.
  23. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    #23 Hans, Nov 21, 2013
  24. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Looks good
  25. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #25 sp1der, Nov 23, 2013
    lm2504me likes this.
