430 \ 360 anyone lower their car on the factory coil overs | Page 2 | FerrariChat
Discussion in '360/430' started by carguy007, Mar 3, 2020.
  1. Eric C
    Eric C F1 Veteran
    9,100
    St. Louis, MO
    Eric
    Awesome! I just ordered that type. Any other pointers? I just ordered some lubricant also.
  2. Dean Palmer
    Dean Palmer Formula Junior
    May 21, 2010
    406
    St. Petersburg, FL
    Dean Palmer
    Yeah, lube the threads well :) My advice is to take your time and figure the best anges to get both spring compressors to have a decent grab on the springs. Work them in and around the a-arms. You really should not need to compress them a long way, just enough to take some pressure off and move the rings. Lowering seems to be the easy direction.
  3. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Eric do you have a link of where you're getting it from? Looks different from the ones on Amazon
    Please and thanks
  4. azzurribaggio
    azzurribaggio Formula Junior
    Flea7 and dr_rob like this.
  5. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Don’t understand why you would lower the car and make it handle worse.
    Get the correct springs please.
  6. Dean Palmer
    May 21, 2010
    406
    St. Petersburg, FL
    Dean Palmer
    These are the factory springs in most cases, and the suspension is already adjustable from the factory. Does not mean the car handles incorrectly if you adjust the suspension as provided by the factory.
  7. one4torque
    5,123
    Houston
    One4torque
    I would agree w the prior tech post above... lowering on stock springs by reducing preload adversely affects handling.
    correct method new springs....
    I would do it this way on a perf car
    All my opinion.
    it’s worth what you pay for :)
  8. Dean Palmer
    May 21, 2010
    406
    St. Petersburg, FL
    Dean Palmer
    Agreed 100%... When you try and go outside the bounds of what the manufacturer provides, things are not optimum. I see some cars really lowered past what I'd consider reasonable. Other suspension parts also reach outside their intended limits of performance or even adjustment even when changing springs.
    Now that we are talking about cars that are a minimum of 11 years old, we also must consider that stock pats may no longer be in spec for the intended use or adjustment.
  9. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    192
    Lots of conflicting views over the years on here as to how well this works, but I thought it was generally accepted that the stock 430 springs/US ride heights were compromised (as in too soft and too high) and that the only way to address the issue properly was fitting Novitec or H&R springs.
    As H&R springs generally seem to get a bad rap in Europe (for being too harsh and too crashy) the Novitec springs, whilst expensive, were generally considered the go to option ?
    The idea of dropping 30-35 mm whilst utilising the standard, soft springs, sounds like a recipe for damage to the damper internals in the long term (or running on the damper's internal bumpstops) with the possibility the springs could becoming unseated over a fast crest in the road. The latter would of course be fixable by fitting some light poundage helper springs such as these :
    https://eibach.com/us/c-113-products-motorsport-springs-accessories-helper-and-tender-springs.html
    but they're not cheap, so far better to put the money towards a set of Novitec springs and do the job right in the first place IMO.
  10. Performify
    Performify Formula Junior
    372
    Sarasota, FL
    Eric
    H&R springs list as only fitting the 2000-2005 360. Any known issues with them on the 1999?
    I have an appointment to lower my car about an inch next week on the factory coilovers (as recommended unprompted by my master tech, actually, when he saw my wheel gap with the 360 challenge wheels) but for the price (about $400) was thinking of upgrading to the H&R springs if I'm going to do it...
  11. 24000rpm
    24000rpm F1 Rookie
    why lowering the car will make it handle worse? :eek:
  12. one4torque
    5,123
    Houston
    One4torque
    24k ok if done properly.
    but slamming down on stock susp not ideal
  13. 24000rpm
    24000rpm F1 Rookie
    hm.......... i might pull the CS & modena front spring and have a comparison.
  14. clean512
    clean512 Formula 3
    2,029
    Josh @jtcarprojects
  15. 24000rpm
    24000rpm F1 Rookie
    i recently found partially why I love the 360 look better
    the 430 is so high compared to the 360
  16. Blue360
    Blue360 Rookie
    Jan 31, 2010
    19
    Newport Beach
  17. ridege55
    ridege55 Formula 3
    1,339
    Manhattan Beach, CA
    Thank you. They are Molulare B18 Evo 20”
  18. Performify
    372
    Sarasota, FL
    Eric
    turns out I will not be lowering my car today on the factory coils. rear shock blown, which probably means all shocks need to be replaced... which leads me immediately to start evaluating aftermarket coilover kits as a more cost effective solution but obviously giving up the electronic dampening.
  19. brookliner7
    brookliner7 Formula Junior
    May 5, 2018
    780
    San Antonio, TX
    Hans
    I have a 1999 euro spec and run H&Rs just fine.
    crinoid, 02360spider, Flea7 and 2 others like this.
  20. Eric C
    Eric C F1 Veteran
    9,100
    St. Louis, MO
    Eric
    I decided to have the shop do mine this week. They weren't able to get the collars to budge on the car, so they're going to remove them and adjust them. They lubed them up the day before and compressed them, but didn't feel comfortable forcing them.
  21. RichardCH
    RichardCH F1 Rookie
    4,661
    Tackleberry great post, any pics of your car on Scud springs please ? what else have you done besides suspension, airboxes and Ferrari Oem Sport exhaust ?
    Tackleberry likes this.
  22. Tackleberry
    Tackleberry Formula Junior
    364
    United Kingdom
    Thank you Richard.
    Only Fabspeed Headers, which were fitted at the same time as the Exhaust.
    A selection of pics for you........
    FOC Goodwood Track Day 2019
    Goodwood FOS parking 2019
    Best of Italy Tour 2019
    RichardCH, Flea7 and SpencerMarks like this.
  23. wtam608
    wtam608 Rookie
    Sep 24, 2015
    28
  24. Alleykat
    Alleykat Karting
    Apr 2, 2009
    163
    Houston,Tx
    Alex
    Oh man those wheels look so good on there.
    brookliner7 likes this.
  25. RichardCH
    RichardCH F1 Rookie
    4,661
    I would therefore guess that US cars have different springs than European cars ? can anyone confirm this. I had my Ferrari dealer lower mine when it was new and realign, my F430 is actually a little lower than my SCUD, I just have to drive slowly over speed humps
